zhangjiali
how to config gmii to rgmii ip in petalinux
my project infomation is as follows:
vivado project:
device tree:
        ethernet@e000b000 {
            compatible = "cdns,zynq-gem", "cdns,gem";
            reg = <0xe000b000 0x1000>;
            status = "okay";
            interrupts = <0x0 0x16 0x4>;
            clocks = <0x1 0x1e 0x1 0x1e 0x1 0xd>;
            clock-names = "pclk", "hclk", "tx_clk";
            #address-cells = <0x1>;
            #size-cells = <0x0>;
            enet-reset = <0x5 0x9 0x0>;
            gmii2rgmii-phy-handle = <0x5>;
            phy-mode = "rgmii-id";
            xlnx,ptp-enet-clock = <0x69f6bcb>;
            local-mac-address = [00 0a 35 00 1e 53];
            phy-handle = <0x6>;
            mdio {
                phy@8 {
                    device_type = "ethernet-phy";
                    reg = <0x8>;
                    compatible = "xlnx,gmii-to-rgmii-1.0";
                    phy-handle = <0x6>;
                    linux,phandle = <0x5>;
                    phandle = <0x5>;
                phy@1 {
                    reg = <0x1>;
                    linux,phandle = <0x6>;
                    phandle = <0x6>;
the u-boot information:
Zynq> mii info
PHY 0x00: OUI = 0x0732, Model = 0x11, Rev = 0x06,  10baseT, HDX
PHY 0x01: OUI = 0x0732, Model = 0x11, Rev = 0x06,  10baseT, HDX
PHY 0x08: OUI = 0x0000, Model = 0x00, Rev = 0x00,  10baseT, HDX
when I boot the linux,  and got the information:
libphy: Fixed MDIO Bus: probed
libphy: mdio_driver_register: xgmiitorgmii
CAN device driver interface
libphy: MACB_mii_bus: probed
mdio_bus e000b000.etherne:08: mdio_device_register
xgmiitorgmii e000b000.etherne:08: Couldn't find phydev
macb e000b000.ethernet eth0: Cadence GEM rev 0x00020118 at 0xe000b000 irq 145 (00:0a:35:00:1e:53)
RTL8211F Gigabit Ethernet e000b000.etherne:01: attached PHY driver [RTL8211F Gigabit Ethernet] (mii_bus:phy_addr=e000b000.etherne:01, irq=-1)
and when I login linux, I can't get a IP address;when I set a static IP,I can't ping the host PC.
zhangjiali
u-boot information:
ethernet@e000b000 Waiting for PHY auto negotiation to complete.... done
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
BOOTP broadcast 6
BOOTP broadcast 7
BOOTP broadcast 8
BOOTP broadcast 9
BOOTP broadcast 10
BOOTP broadcast 11
BOOTP broadcast 12
BOOTP broadcast 13
BOOTP broadcast 14
BOOTP broadcast 15
BOOTP broadcast 16
BOOTP broadcast 17
Retry time exceeded
Hit any key to stop autoboot:  0
Zynq> mii info
PHY 0x00: OUI = 0x0732, Model = 0x11, Rev = 0x06, 100baseT, FDX
PHY 0x01: OUI = 0x0732, Model = 0x11, Rev = 0x06, 100baseT, FDX
godevin
I'm having the exact same issue. Have you sorted out how to make it work?
sdyang
I have the same issue.
Always Online
godevin
If it can helps, here is what I endde up be using to have it partially running. I couldn't get the gigabit working but at least I did have 10 and 100 mbits available.
&gem0 {
  phy-handle = <&phy0>;
  status = "okay";
  xlnx,ptp-enet-clock = <0x69f6bcb>; // Set clock to 111MHz?
  local-mac-address = [00 0a 35 00 02 90];
  gmii2rgmii-phy-handle = <&gmii_to_rgmii_0>;
  psu_ethernet_0_mdio: mdio {
    #address-cells = <1>;
    #size-cells = <0>;
    phy0: phy@1 {
      reg = <1>;
    gmii_to_rgmii_0: phy@8 {
      reg = <8>;
abcdefjxz
I am having the same problem. Have you sorted out?
abcdefjxz
I am having the same problem avout gmii2rgmii. Have you sorted out?
