Visitor flytercel
how to creat a jffs2 file system with petalinux
spartan3e board
when i try to make a jffs2 file system with petalinux,some error happen"jffs2 not support"
but in the linux kernel configuration i have choose the jffs2 support :
File systems ---> Miscellaneous filesystems --->
<*>JournallingFlash File System v2 (JFFS2) support
[*]JFFS2write-bufferingsupport
[*]AdvancedcompressionoptionsforJFFS2
[*]JFFS2ZLIBcompressionsupport
[*]JFFS2RTIMEcompressionsupport
[*] JFFS2 RUBIN compression support
can anybody help me! thank you
Re: how to creat a jffs2 file system with petalinux
How are you trying to create the file system? The tool you're using may not support it, even if the kernel has j2ffs support compiled in.
Cheers,
Rob
Visitor flytercel
i have creat a cramfs file system before,it can use ,but it is read-only file syetem ,so i want creat a read-write file system ,
can you tell me what can i do ?
thanks
Advisor joelby
Advisor
Normally you'd create the filesystem using the mkfs.jffs2 tool. Do you have this installed?
