how to do XIP linux on flash
I want to run XIP linux on flash. Does current kernel release support XIP feature?
I configure the option "Kernel XIP on ROM", and make xipImage. Then download the xipImage to flash. When uboot is start, using "go" command to jump to xipImage start address. But the the kernel isn't lanuched. BTW, my devicetree and ramdisk are in DDR.
Does anyone run XIP linux on flash? Does the xipImage which is generated by "make xipImage" work?
