how to enable tcf agent in linux2014.4
Hi everybody
i build the kernel 2014.4 from xilinx offical github,  and the whole system is running on Zynqplatform
I have a requirement about debug online using enable tcf agent
if I am not use  the Petalinux, can I use the TCF agenet in Kernel2014.4
and vivado sdk is 2015.4 ?
Re: how to enable tcf agent in linux2014.4
Hi @phdwong
If you are using petalinux, then we have a older UG1144 guide to enable TCF
https://www.xilinx.com/support/documentation/sw_manuals/petalinux2014_4/ug1144-petalinux-tools-reference-guide.pdf
(Debugging Zynq Applications with TCF Agent)
Hi @phdwong
tcf-agent is debugger utility, this has to enabled in your rootfs.
here the AR which will help you to enable the basic kernel configurations for debug support, along with tfc-agnet in rootfs.
:https://www.xilinx.com/support/answers/66853.html
For debugging application using SDK
https://www.xilinx.com/support/documentation/sw_manuals/xilinx14_6/SDK_Doc/tasks/sdk_t_tcf_standalone_app_debug_tcf.htm
Thanks & regards
Aravind
Hi @aravindb
Thank you for you answer,  from the AR,
in our kernel I can find the setting ,but Rootfs is not.  I generate the Rootfs by busybox, the version is not suit for TCF ?
Hi @phdwong
Hi @shabbirk
I use the linux 2014.4 from xilinx github, not use the petalinux because all driver developed on xilinx kernel 2014.4
Hi @phdwong
In that case, build the tcf-agent & tcf-client from sources, extract the rootfs tar and add this built tcf binaries and compress it back.
How to on build & modify rootfs here:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842473/Build+and+Modify+a+Rootfs
