how to get libc.so with symbol file?
on our proudct with  xilinx-v2015.4 , when the kernel crash happened, we can't decode the trace inside some libs like libc.so, seems no sysmbol, is there any way to get the dynamic lib with symbols file inside?
Hi @chnchl
I dont think we have a provision to debug the library if that if that is not build with debug symbols.
Please buld with libraries with enabling debug symbol & try.
Thanks & regards
Aravind
