how to mount sd card on open source linux??
Hi Guys
I am trying to mount sd card after booting linux(open source) from sd card but i m seeing an error saying 'invalid argument'
zynq> mount -t vfat /dev/mmcblk0 /mnt/
mount: mounting /dev/mmcblk0 on /mnt/ failed: Invalid argument
zynq> mount  /dev/mmcblk0 /mnt/
I believe that linux has detected the card as if I try fsdik -l, its showing me the right results:
zynq> fdisk -l
Disk /dev/mmcblk0: 7948 MB, 7948206080 bytes
4 heads, 16 sectors/track, 242560 cylinders
Units = cylinders of 64 * 512 = 32768 bytes
        Device Boot      Start         End      Blocks  Id System
/dev/mmcblk0p1             129        8320      262144   b Win95 FAT32
Partition 1 does not end on cylinder boundary
/dev/mmcblk0p2            8321      242560     7495679+  f Win95 Ext'd (LBA)
Partition 2 does not end on cylinder boundary
/dev/mmcblk0p5            8322      242560     7495648   7 HPFS/NTFS
I found a similar thread : https://forums.xilinx.com/t5/Embedded-Linux/mount-mounting-dev-mmcblk0p1-on-mnt-failed-Invalid-argument/m-p/432116#M8371
and the accepted solution says 'check if sd-card is enabled in your design' but there the designer booted from qspi and not from sd card and in this case, I actually booted linux from sd card.
Thank you very much for your time!
Mentor
Mentor
Re: how to mount sd card on open source linux??
Hi @ali.digitekeng
Would you execute the following command ?
$ mount /dev/mmcblk0p1 /mnt/boot
$ mount /dev/mmcblk0p2 /mnt/
Bets regards,
Mentor
Mentor
Hi @ali.digitekeng
Bets regards,
Hi Watari
Thanks for the reply. I tried the commands you suggested
zynq> cd /mnt/boot/
zynq> ls
BOOT.bin                   devicetree.dtb             uramdisk.image.gz
System Volume Information  uImage
zynq> mkdir test_dir
mkdir: can't create directory 'test_dir': Read-only file system
So the first command mount worked but I cant write anything in that partition.
For the second comamnd
zynq> mount /dev/mmcblk0p2  /mnt/
EXT4-fs (mmcblk0p2): unable to read superblock
EXT2-fs (mmcblk0p2): error: unable to read superblock
mount: mounting /dev/mmcblk0p2 on /mnt/ failed: Invalid argument
I am not able to mount the second partition. For the first problem(readonly mount) I even tried to add -w switch but it didnt help either
Please suggest
Update:
I found that my sd card had partitioning issue. After fixing it, I can mount both partitions.
Now the only issue is I cant write on either partitions.
mkdir: can't create directory 'test_dir' : Read-only file system
PS: I created two partitions, one for linux boot stuff and other for my applications and other data
Update
I found this AR:
https://www.xilinx.com/support/answers/61064.html
After reading it I found that write protect pin was floating in my design. I assigned a constant 0 and that solved the writing issue.
This thread is closed.
