how to run applicaiton using all cores of cortex-a53
I am ruining Pthread application on cortex-a53 which has 4 cores. And I also run the same application on the server with 8 arm cores to make a comparison.
A problem is there is bare performance improvement on cotex-a53 with 4 cores. However the improvement on 8-arm cores server is obvious when increase the thread from 1-8. See below:
fig.1
I am suspect that the cotex-a53 only working with one core (not four) with the pthread application. So I checked the status of the 4 cores using XSCT in SDK when I running my application. The result shows only one core is in running status see that below:
fig. 2
I am not sure whether it is believable to check the status of the cores using XSCT. But according to the result from XSCT and result on fig.1 it seems only on core of the 4 cortex-53 is running.
Does anyone could help me confirm whither I am  correct or not?
If my suspect is corrt, how could I run the application on 4 cores at the same time?
Thanks in advance.
Teacher muzaffer
Re: how to run applicaiton using all cores of cortex-a53
@mathmaxsean it seems like you are running in the stand-alone mode. If yes, that mode doesn't support multi-threading. You need a multi-threaded OS (ala linux) to do that.
I am using linux application mode and it is not stand alone mode.
I build the applicaiton and run it on the linux.
Now just only one core working no matter how much threads I use.
I tried to bind the thread to different cores with the function of  pthread_setaffinity_np :http://man7.org/linux/man-pages/man3/pthread_setaffinity_np.3.html
But still cannot invoke the other three cores of cortex-a53. But the same code could work on an arm server.:
I tried this functions.as below  (the code's function (source: at the end of the text ) is create a thread and execution the thread on each core):
The result from arm server (which has 8cores):
The result from the Cortex-a53 (has 4 cores) in the Zynq UltralScale+ MpSOC:
The system can detect 4 cores but cannt run the thread on they other three cores.
I wonder do we need to enable some function of the linux system or petalinux/SDk.
I also check my arm-linux system, The SMP is enable.
What else?
The code I used.
#define _GNU_SOURCE
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
#include <pthread.h>
#include <sched.h>
void *myfun(void *arg)
    cpu_set_t mask;
    cpu_set_t get;
    char buf[256];
    int i;
    int j;
    int num = sysconf(_SC_NPROCESSORS_CONF);
    printf("system has %d processor(s)\n", num);
    for (i = 0; i < num; i++) {
        CPU_ZERO(&mask);
        CPU_SET(i, &mask);
        if (pthread_setaffinity_np(pthread_self(), sizeof(mask), &mask) < 0) {
            fprintf(stderr, "set thread affinity failed\n");
        CPU_ZERO(&get);
        if (pthread_getaffinity_np(pthread_self(), sizeof(get), &get) < 0) {
            fprintf(stderr, "get thread affinity failed\n");
        for (j = 0; j < num; j++) {
            if (CPU_ISSET(j, &get)) {
                printf("thread %d is running in processor %d\n", (int)pthread_self(), j);
        j = 0;
        while (j++ < 100000000) {
            memset(buf, 0, sizeof(buf));
    pthread_exit(NULL);
int main(int argc, char *argv[])
    pthread_t tid;
    if (pthread_create(&tid, NULL, (void *)myfun, NULL) != 0) {
        fprintf(stderr, "thread create failed\n");
        return -1;
    pthread_join(tid, NULL);
    return 0;
