ardealliang
how to set env variable on ubuntu 16.04 for petalinux 2018.2
I have installed petalinux.
what are the variables should be set?
export ARCH=?
export CROSS_COMPILE=?
shabbirk
Hi @ardealliang
Yes you are right. To work with petalinux, you need only the PetaLinux 2018.2 Installer
Best Regards
Shabbir
hokim
petalinux has the shell script file for environment setting
source /opt/petalinux/2018.2/settings.sh
ardealliang
Hi Hokim,
I have run the command:
source /opt/Xilinx/SDK/2018.2/settings64.sh
but no output could be seen on Ubuntu.
I also checked the env, and didn't find the variable set by the sh.
It seems that the sh file didn't run.
Best Regards,
Ardeal
shabbirk
Hi Ardeal
After running source /opt/Xilinx/SDK/2018.2/settings64.sh, are you able to launch xsdk in your ubuntu?
Also, for petalinux you dont need to set any environment variables to build the project. You will have to just install the petalinux and source the petalinux's settings.sh or settings.csh and then create and build the petalinux project
FYI, you can refer to this UG1144 (Installation requirements section)
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug1144-petalinux-tools-reference-guide.pdf
Best Regards
Shabbir
aravindb
HI @ardealliang
You no need to export any environment variables(ARCH & CROSS_COMPILE) if you use the petalinux to build the SW.
You just need to run the below  settings script, this will export all the environment variables required for petalinux build.
source /proj/petalinux/petalinux-v2017.3_daily_latest/petalinux-v2017.3-final/settings.sh
Thanks & regards
Aravind
ardealliang
Hi @aravindb,
The following is my petalinux path:
root@ubuntu /opt/Xilinx/SDK/2018.2#ls
bin  data  doc  eclipse  gnu  lib  scripts  settings64.csh  settings64.sh  tps
when I run source /opt/Xilinx/SDK2018.2/setting64.sh, nothing happens.
no variables are set, nothing displayed on the monitor.
Best Regards,
Ardeal
shabbirk
Hi Ardeal
It is not petalinux installation settings, it is just SDK settings. Refer my previous post on setting petalinux path
ardealliang
Hi @shabbirk,
Thanks for your reply!
Could you tell me the command to set petalinux envrionment?
My petalinux locate at:
Thanks and Best Regards,
Ardeal
shabbirk
Hi Ardeal
This is not petalinux installation path.
First install the petalinux by downloading petalinux installer from xilinx website
https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/embedded-design-tools.html
Also, make sure before installing petalinux, you will have to install set of packages and steps to install these are described in UG1144
Best Regards
Shabbir
ardealliang
I read the pdf file in your link.
There is no settings.sh file in my petalinux folder.
ardealliang
I search settings.sh, but cannot find the file.
It seems that my petalinux is different from yours.
I installed it with the following command:
mkdir -p /opt/pkg/petalinux
./petalinux-v2018.1-final-installer.run /opt/pkg/petalinux
shabbirk
Can you go to this path and check?
/opt/pkg/petalinux
Best Regards
Shabbir
ardealliang
it is empty
when I run the command
./Xilinx_SDK_2018.2_0614_1954_Lin64.bin /opt/pkg/petalinux
the default installation folder is /opt/Xilinx but not /opt/pkg/petalinux
shabbirk
Hi Aredeal
Now, try to install again here
ardealliang
Hi @shabbirk,
Do you mean I should re-download the file petalinux-v2018.1-final-installer.run or re-run my existing file Xilinx_SDK_2018.2_0614_1954_Lin64.bin?
Best Regards,
Ardeal
shabbirk
Hi @Ardeal
Just copy the petalinux-v2018.1-final-installer.run in this path /opt/pkg/petalinux and run ./petalinux-v2018.1-final-installer.run .
No need to re-download
ardealliang
Hi @shabbirk,
From Xilinx web page:
I could download SDK 2018.2 Web Install for Linux 64 (BIN - 99.29 MB)
should I download this BIN and run?
Best Regards,
Ardeal
ardealliang
Hi @shabbirk,
When I re-run the command:
./Xilinx_SDK_2018.2_0614_1954_Lin64.bin .
I choose  XSDK when there are 3 choice: XSDK , XSCT and BootGen
I got the final result as follows:
shabbirk
Hi @ardealliang
Can you please confirm, what is that you are looking for?
To install SDK or to install petalinux?
Best Regards
Shabbir
ardealliang
Hi Shabbirk,
I would like to install petalinux to compile Linux or C code for ARM on Zynq of zedboard.
I downloaded the petalinux tool from here:
https://www.xilinx.com/products/design-tools/embedded-software/petalinux-sdk.html
Best Regards,
Ardeal
shabbirk
Hi Ardeal
If petalinux is your requirement, dont focus on SDK or ./Xilinx_SDK_2018.2_0614_1954_Lin64.bin installer
Instead, focus only on petalinux installer.
If you dont find settings.sh in this path /opt/pkg/petalinux/petalinux-v2018.2-final/  follow the below steps
Before installing or running petalinux installer, install the packages as described in page 9, 10 and 11 of the below user guide
And, Follow these steps for petalinux installation:
1. mkdir -p /opt/pkg/petalinux
2. Provide user permissions to /opt/pkg/petalinux
3. ./petalinux-v2018.1-final-installer.run /opt/pkg/petalinux
4. ls /opt/pkg/petalinux/petalinux-v2018.2-final/ and check for settings.sh
5. Then source /opt/pkg/petalinux/petalinux-v2018.2-final/settings.sh
ardealliang
Hi Shabbirk,
I eventually got it:
To install PetaLinux,
I should download PetaLinux 2018.2 Installer (TAR/GZIP - 6.15 GB) , but not SDK 2018.2 Web Install for Linux 64 (BIN - 99.29 MB)
Thanks!
Best Regards,
Ardeal
shabbirk
Hi @ardealliang
Best Regards
Shabbir
ardealliang
Hi Shabbirk,
Do you have any idea about the question:
https://forums.xilinx.com/t5/Embedded-Linux/Reproduce-the-Matlab-example-in-C-code-Receive-Tone-Signal-Using/td-p/904206
Best Regards,
Ardeal
shabbirk
Hi @ardealliang
I dont have any idea on this thread. I will ask any of my colleagues to respond on this thread if they know
Also, please mark this thread as an accepted solution to close the further discussion on this thread
Best Regards
Shabbir
