how to setup ethernet on open source linux
I am using zybo board. I configured MIO to connect to Ethernet. I am using open source linux to setup ethernet. I am assuming that ethernet driver is up and running. I did the following so far:
zynq> ip link set eth0 up
IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
zynq> ifconfig
eth0 Link encap:Ethernet HWaddr 00:0A:35:00:01:22
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:27 Base address:0xb000
zynq> ifconfig eth0 192.168.1.0
zynq> ifconfig
inet addr:192.168.1.0 Bcast:192.168.1.255 Mask:255.255.255.0
from above results, i m assuming ethernet driver is up and running but I cant ping any IP on internet nor I can ping my zybo board from another computer.
Could somebody please help me understand what am I missing?   My end goal is to do basic socket programming to fetch data and process.
Thanks you very much for your time!!!
Re: how to setup ethernet on open source linux
Please consider this thread closed. The issue was related to ethernet configurations missing in fsbl and I noticed it from u-boot. During u-boot i saw a message that 'no ethernet found'.
After fixing that, I just had to up the link, setup IP and gateway. Now, ping test is passing within the LAN and for internet as well.
Thanks to all of you!!
Has anybody tried to access LAN with opensource linux?
Should I try peta linux instead?
Hardware: Digilant Zybo board
Hi @ali.digitekeng
I would rather suggest to first refer xapp1082 which is based on petalinux 2018.1
https://www.xilinx.com/support/documentation/application_notes/xapp1082-zynq-eth.pdf
Best Regards
Shabbir
