how to switch i2c controller mode in the linux application?
I use zynq to connect a BMC. They use i2c channel to transfer ipmi data.
In the ipmi specifications,zynq i2c controller needs to change modes between i2c master and i2c slave.
I have known the i2c controller driver (i2c-cadence) supports both master and slave mode. But I do not know how to switch modes in the linux app.
Can someone tell me how to solve the problem?
Thanks very much~
Re: how to switch i2c controller mode in the linux application?
Hi @felven,
We have validated zynq i2c slave mode using aardvark adapter as master. This adapter can be configured as master/slave. in our case its a master to read/write data to i2c slave(zynq).
Run 'echo slave-24c02 0x10xx > /sys/bus/i2c/devices/i2c-y/new_device' on the board after
bootup.
Here xx is the 7 bit slave address configured in aardvark adapter (we have set it 0x64 for a test)
and y is the I2C device ID, where ZCU102 will be configured as I2C slave. In 2017.1 Petalinux,
ZCU102 I2C controller is on I2C-1.
We have selected slave address as 0x64 and hence, command is,
'echo slave-24c02 0x1064 > /sys/bus/i2c/devices/i2c-1/new_device'
Kranthi
Best Regards
Kranthi
Thanks for your reply. But my question is how to switch i2c mode in linux app. So users can use linux app to operate the controller.
Hi @felven,
In User space we have a system call called "system". you can execute Linux command from user space by passing it as argument to it.
Below are the links to few system() function examples.
https://www.codingunit.com/c-reference-stdlib-h-function-system
https://www.techonthenet.com/c_language/standard_library_functions/stdlib_h/system.php
you have to include this system function in your linux app.
Kranthi
Best Regards
Kranthi
Could you give a more detailed description?
Do you mean I use system() function to operate the linux driver working in different modes? But I am still confused how to change the drivers operation when the linux boots up.Could you give an example? Thanks very much.
