how to use bsp in linux apllication
Hi, how to use bsp which generated when creating standalone application in linux apllication. For when creating linux application there no BSP(ps7_cortexa9_0 libs) provided.
Hi @in_peace
Linux userspace application cannot access to the physical memory address so the BSPs provided within SDK/Vitis are intended to be used for standalone/RTOS use cases.
When developing Linux userspace applications usually you would be looking into using the Linux drivers.
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841873/Linux+Drivers
Ibai
