abhishekkunal
how to use dmaproxy module in petalinux
i am trying to figure out how to use dmaproxy module for data transfer in petalinux.
Module is present in /dev directory but dont know how to use it.
Also i wanted to know how reserve physical memory to use it from userspace in petalinux.
As de/mem is not allowing me to access ddr memory.
jrhtech
Voyager
Voyager
I haven't looked at the dma-proxy code for a while but you will have to drive the device via ioctls in userspace.
You can reserve memory in the devicetree like this:
reserved-memory {
#address-cells = <2>;
#size-cells = <2>;
ranges;
mojo_dispcal_reserved: mdcal@40000000 {
no-map;
reg = <0x0 0x40000000 0x0 0x1000000>;
and then you just mmap that region.
Are you saying the command devmem is not working or you can mmap /dev/mem ?  Are you running as root?  I've never seen devmem not work but I'm always root.
jeff
abhishekkunal
HI,
Thanks for suggestion i tried to reserve memory as you suggested and tried mmap @0x40000000 but it failed. "Operation not permitted"
int m=open("dev/mem",o_RDWR);
unsigned int* vir_add = mmap(NULL,65535, PROT_READ | PROT_WRITE , MAP_SHARED, m,0x40000000);
jrhtech
Voyager
Voyager
It’s /dev/mem
are you root ?
and you should just try the devmem or peel/poke tools since they do the same thing
jeff
abhishekkunal
HI,
Sorry for the typo, i am using as "/dev/mem" only.
Yes i am running as root and also tried from terminal ( devmem 0xmemadd ) it says mmap not permitted. Same for /dev/mem
I cant find peel/poke in my linux build. Would you let me know the settings i need to do for this.
I have "filter to dev/mem access" disabled in petalinux kernel settings. Still its not allowing me to access physical memory from user space in petalinux.
