wanna
how to use dpdma in linux?
Ok,I have some video data at DDR memory,similar to a framebuffer.Now, I want to use dpdma to move data to Display Port and display in linux. I refer baremetal dpdma code and linux device tree, I directly mmap register address of dpdma to linux userspace and configure it,but I failed, can you give me some suggestion,thank you!
florentw
HI @wanna
There should be a driver in linux so you do not have to configure the registers directly.
The Zynq UltraScale MPSoC Base TRD is using the Displayport Controller with the DPDMA you might want to have a look on how it is working
Florent
wanna
@florentw
Thank you for reply my post; I haven't found any code about the  Zynq UltraScale MPSoC Base TRD, dpdma driver is exist in linux, I should how to use;
wanna
I use petalinux version is 2018.3 and  zcu104 board.
florentw
Hi @wanna
Unfortunately the TRD is the only the resource I know showing an example using the DPDMA. But keep in mind again that this is using the driver so there is no code in the userspace. This is all managed at framework level
Florent
wanna
@florentw
OK, Thanks, your meaning that I should  operate  in linux driver layers rather than user layer when I want to use dpdma driver.  can v4l2 driver solve the problem?  or need myself to edit a driver to invoke dpdam driver.
florentw
Hi @wanna
Because this is associated with the Dp controller, you need to use the DRM KMS driver.
Then you can control the flow using Gstreamer
Florent
