how to use i2c-cadence driver in slave mode?
I find i2c-cadence driver has added slave mode according to the wiki page. http://www.wiki.xilinx.com/Cadence+I2C+Driver
However, the wiki page did not give the test procedure for the i2c-cadence in slave mode.
I know I should added CONFIG_I2C_SLAVE in the kernel config file. But I do not know how to set the i2c slave address and how to communicate with the master.
Can someone give me a test procedure just like the wiki page ?
Thanks very much.
Hi Felven
I'm sorry i can not help you.I wonder are you a blogger of CSDN?? I think Your blog post is very helpful.
If you are, Can you help me with a question about enable the UART0 in the Zynq PS?
Any reply will be thanked.
Hi @felven,
You can use attached docuement to refer the steps on how to validate slave mode.
We have tested on Zynq Utlrascale and used aardvark adapter as master.
Please mark post as accepted solution if provided information is helpful for you.
Best Regards
Kranthi
What's your question?
thanks, but I do not have aardvark i2c master adapter.
