how uninstall Petalinux
I want uninstall Petalinux 2018.4 and install Petalinux 2016.4 instead. What's correct procedure?
Hi @olkhramus
There is no uninstall script provided with Petalinux. Deleting the entire petalinux installation directory would be sufficient. Fox example: rm -rf /opt/Xilinx/petalinux
Please consult UG1144 for the petalinux version desired to get more information about the installation requirements and procedure. For 2016.4, it can be found at https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_4/ug1144-petalinux-tools-reference-guide.pdf
Best.
