in petalinux 2017.2, where to search my own header file?
hi all,
In petalinux 2015.4, after creating my apps, I can put my header file and .c file in the same directory.
But in 2017.2, the compiler will complain that the header can't be found.
As I know, if i use
#include "f1.h"
the compiler should search for f1.h in the same directory as the source file at first.
So what is the search order for compiler in 2017.2?
regards
Chao
why nobody answer this simple question?
can you post the hole message?
