init scripts (2017.4)
I'm following "Steps for Application Auto Run at Startup" in UG1144 (2017.4) and I am not getting the link being made into the rcS.d directory.  The script is there in /etc/init.d/
Is this working for other people?
Re: init scripts (2017.4)
I moved udev from rcS.d to rc5.d and now I can boot without a PL in QSPI.  I have a bit.bin in my image.ub and it is loaded in rc.5 before udev.  The boot no longer hangs.
Just letting people know what I had to do in case there was anyone else needing the same thing.
Hi mark@bish.net,
I don't see any problem with 2017.4 Can you post your loadPL content?
test-init.bb content
# This file is the test-init recipe.
SUMMARY = "Simple test-init application"
SECTION = "PETALINUX/apps"
LICENSE = "MIT"
LIC_FILES_CHKSUM = "file://${COMMON_LICENSE_DIR}/MIT;md5=0835ade698e0bcf8506ecda2f7b4f302"
SRC_URI = "file://test-init \
inherit update-rc.d
INITSCRIPT_NAME = "test-init"
INITSCRIPT_PARAMS = "start 99 S ."
S = "${WORKDIR}"
do_install() {
	     install -d ${D}${sysconfdir}/init.d
	     install -m 0755 ${S}/test-init ${D}${sysconfdir}/init.d/test-init
FILES_${PN} += "${sysconfdir}/*"
test-init content
#!/bin/sh
DAEMON=/usr/bin/test
start ()
	echo " Starting test"
	start-stop-daemon -S -o --background -x $DAEMON
stop ()
	echo " Stoping test"
	start-stop-daemon -K -x $DAEMON
restart()
	stop
	start
[ -e $DAEMON ] || exit 1
	case "$1" in
		start)
			start; ;;
		stop)
			stop; ;;
		restart)
			restart; ;;
			echo "Usage: $0 {start|stop|restart}"
			exit 1
	esac
exit $?
Sandeep
I put the same script you have into my recipe and still no luck.  Is petalinux/Yocto trying to use the update-rc.d that is native to the host?
I am using Debian.  And I have copied update-rc.d into /opt/pkg/petalinux/2017.4/tools/linux-i386/petalinux/bin/ just in case it was looking for it.
Hi mark@bish.net,
This is not native to host. You don't need to add any packages to petalinux installer.
Their is a recipe for this https://github.com/openembedded/openembedded-core/blob/morty/meta/recipes-core/update-rc.d/update-rc.d_0.7.bb.
Also you can try updating manually like this.
root@xilinx-zcu102-zu9-es2-rev1_0-2017:~# update-rc.d test-init defaults
 System startup links for /etc/init.d/test-init already exist.
Sandeep
If I don't need to add it, any advice on debugging why it isn't working then?
@sandeepg Also, is there  a way I change the init levels of scripts in /etc/rcS.d/  I want to move S05modutils.sh to S15modutils.sh
Hi mark@bish.net,
You can override in modutils-initscripts.bbappend as shown below.
$ mkdir -p <plnx-proj-root>/project-spec/meta-user/recipes-kernel/modutils-initscripts/
$ touch <plnx-proj-root>/project-spec/meta-user/recipes-kernel/modutils-initscripts/modutils-initscripts.bbappend
# Add this content INITSCRIPT_PARAMS = "start 15 S ."
Sandeep
@sandeepg  Thank you for that.
Also, is there a way to get past udev when booting into a zynq system that doesn't have a PL loaded by either uboot or the FSBL.
I'm using a dts for the PL I am eventually going to load after I boot.  This dts has some AXI GPIOs defined for PL that will be loaded after I boot.  I have narrowed it down to "udevadm settle" in the udev bootscript, which doesn't return if the PL hasn't been programmed.  I am assuming I can program the PL before the udev script starts and things will just work.
Any ideas?
Hi mark@bish.net,
I would suggest not to use this flow.
Sandeep
I know this isn't directly tied to what you listed as the solution but I came across this post when having a problem very similar to what you described in the opening post. I also followed the "Steps for Application Auto Run at Startup" from p60 of UG1144, saw my script in /etc/init.d and did not see it run.
After a lot of trial and error I found that everything worked when I made sure I used all lowercase letters for my application names. I only thought of this when comparing your code with mine and the Xilinx example in UG1144. I suspect your app would work if named "loadpl" instead of "loadPL."
I hope this saves someone else some time!
Jim
