doreenyen
insmod blink.ko -> Invalid module format, next trying to build against git cloned sources
  Since ug873-zynq-ctt.pdf describes the provided ug873-design-files/LKM/blink.ko as built against ISE 14.3,
and the information below, the next step is build against the git cloned sources.  Neither command line using Makefile below, make all
nor excluding/including Makefile in Vivado 2013.2 SDK 14.6 Application project can build blink.ko
The command line output is:
make ARCH=arm -C /home/doreen/Xilinx/gitLinux/linux-xlnx/ M=/home/doreen/Xilinx/ug873-design-files/LKM modules
make[1]: Entering directory `/home/doreen/Xilinx/gitLinux/linux-xlnx'
  ERROR: Kernel configuration is invalid.
         include/generated/autoconf.h or include/config/auto.conf are missing.
         Run 'make oldconfig && make prepare' on kernel src to fix it.
  WARNING: Symbol version dump /home/doreen/Xilinx/gitLinux/linux-xlnx/Module.symvers
           is missing; modules will have no dependencies and modversions.
  CC [M]  /home/doreen/Xilinx/ug873-design-files/LKM/blink.o
gcc: error: unrecognized command line option ‘-mlittle-endian’
gcc: error: unrecognized argument in option ‘-mabi=apcs-gnu’
gcc: note: valid arguments to ‘-mabi=’ are: ms sysv
make[2]: *** [/home/doreen/Xilinx/ug873-design-files/LKM/blink.o] Error 1
make[1]: *** [_module_/home/doreen/Xilinx/ug873-design-files/LKM] Error 2
make[1]: Leaving directory `/home/doreen/Xilinx/gitLinux/linux-xlnx'
make: *** [all] Error 2
The SDK Console output is:
17:34:27 **** Build of configuration Debug for project blink ****
make all
Building file: ../src/blink.c
Invoking: ARM Linux gcc compiler
arm-xilinx-linux-gnueabi-gcc -Wall -O0 -g3 -c -fmessage-length=0 -MMD -MP -MF"src/blink.d" -MT"src/blink.d" -o "src/blink.o" "../src/blink.c"
../src/blink.c:5:55: fatal error: linux/module.h: No such file or directory
compilation terminated.
make: *** [src/blink.o] Error 1
17:34:27 Build Finished (took 64ms)
# modinfo blink.ko
filename:       blink.ko
depends:
vermagic:       3.5.0-14.3-build2 SMP preempt mod_unload modversions ARMv7
# uname -a
Linux pbzynq1 3.8.0-xilinx-00015-gabc285b #1 SMP PREEMPT Mon Apr 15 09:22:29 PDx
$ cat Makefile
ARCH := arm
# This is the Ubuntu12.10 www.wiki.xilinx/com/Ubuntu+on+Zynq
KER_DIR := /home/doreen/Xilinx/gitLinux/linux-xlnx/
obj-m += blink.o
all:
    make ARCH=$(ARCH) -C $(KER_DIR) M=$(PWD) modules
clean:
    make ARCH=$(ARCH) -C $(KER_DIR) M=$(PWD) clean
dogbytes
sorenb
Did you do what the build system told you? You need a configured kernel tree. Bare sources don't cut it.
doreenyen
Ah, this morning got around to a couple commands additionally run, as below,
    After running the Vivado settings64.sh,
    At the linux-xlnx directory of the Ubuntu kernel:
      cp ./arch/arm/configs/xilinx_zynq_defconfig .config
       make oldconfig
    make prepare
    make modules
so now the blink.ko was built, thanks.
dogbytes
doreenyen
Now the blink.ko linked to the same Linux kernel version for 32bit ARM, so what else causes invalid module format ?
Are there any other diagnostics available ?
# insmod blink.ko
insmod: error inserting 'blink.ko': -1 Invalid module format
# modinfo blink.ko
filename:       blink.ko
depends:
vermagic:       3.8.0-xilinx-00015-gabc285b SMP preempt mod_unload modversions
# uname -a
Linux pbzynq1 3.8.0-xilinx-00015-gabc285b #1 SMP PREEMPT Mon Apr 15 09:22:29 PDT 2013 armv7l armv7l armv7l GNU/Linux
# file blink.ko
blink.ko: ELF 32-bit LSB relocatable, ARM, version 1 (SYSV), BuildID[sha1]=0x22d
dogbytes
doreenyen
Hm,  blink.c does not have any MODULE_ parameters nor
module_init( init_module);
module_exit( cleanup_module);
soooo, gonna try it, stay tuned.
dogbytes
