install 2 version petalinux on same machine
I need to install 3rd party modified petalinux 2014.4, but I already install 2017.2 on my machine.  if I install 2014.4 to different folder would there be any conflict between the two in term of compiler etc etc
thanks
Re: install 2 version petalinux on same machine
There should be no conflict as long as they are installed in separate directories and you source settings.sh from only one version per terminal session. I run 2014.2 and 2016.3 installed on a single VM and they both work just fine as long as I follow that rule.
Participant kallensf
Also ask for the matching version of Vivado for that 3rd party petalinux.  It is usually preferable to use the same version Vivado and petalinux.
I have 3 Peta versions, in different folders:
2017.2: petalinux
2017.1: petalinux_20171
2016.4: petalinux_20164
Source the matching settings.sh.
