install package onto target
Hello!
What is a proper way to install single package on target machine?  For instance, I add mkfs.ext4 through running "petalinux-config -c rootfs && petalinux-build" and petalinux recreates rootfs cpio & tar archives.  But I don`t want to copy and update the whole rootfs on target.  How can I deploy single package, say mkfs, to target?
Currently I use Petalinux 2017.2
Re: install package onto target
Hi Mishuk,
Do you mean , you would like to include rpm as a part of filesystem?
If so you can try this below steps:
Filesystem Packages ---> misc ---> rpm ---> [*] rpm
petalinux-build
Thanks & regards
Aravind
Still no answer?!
Does petalinux have some package manager on the target so I can deploy newly added packages (say, ntp) easily without rewriting whole rootfs?
HI please follow below steps to add mkfs utility into your rootfs
Filesystem Packages ---> base ---> util-linux --->[*] util-linux-mkfs
petalinux-build
For adding ntp please follow below steps:
vim project-spec/meta-user/recipes-core/images/petalinux-image.bbappend
add below line
IMAGE_INSTALL_append = " ntp"
user packages --> [*] ntp
petalinux-build
Thanks & regards
Aravind
I followed your steps and ntpd service apperared on rootfs. But where is ntpq? I found ntpq-utils rpm package in <petalinux-dir>/build/tmp/deploy/rpm/cortexa9hf_neon folder, copied it onto target and installed using "rpm --install --deps". What recipe should I modify to deploy ntp-utils onto rootfs like ntpd itself?
Hi Mishuk,
Follow below steps ,  you will get ntpq as a part of rootfs. I already verified  and i should work for you.
add below line
IMAGE_INSTALL_append = " ntp-utils"
user packages --> [*] ntp-utils
petalinux-build
Hi Mishuk,
petalinux-build
Thanks & regards
Aravind
