lyl666233
install petalinux:E: Unable to locate package xvfb-run
When i was install petalinux in Ubuntu 16.04.3,use sudo apt-get update but still " Unable to locate package xvfb-run". How can i do?
aravindb
HI @lyl666233
Try below commad, hope it should work.
sudo apt-get install xvfb
Thanks & regards
Aravind
