interrupt count in /proc/interrupts is not changing even after changing the value of memory through devmem
I have followed all the steps provided in the following link
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842490/Testing+UIO+with+Interrupt+on+Zynq+Ultrascale
everything is fine I am getting uio0 in linux but after changing the value of the memory location provided in example value of interrupt count is not changing and push button interrupt is also not getting received, kindly help anyone, more information I am using zcu111 and vivado 2019.2 and vitis 2019.2
Hi @f35
  You stated "after changing the value of the memory location provided in example" in your post. Which memory location are you referring to? In the example, the AXI GPIO IP is set to a memory range, which should match with the offset pointed to by /dev/mem access.
-Pat
Give kudos if helpful. Accept as solution if it solves your problem.
https://tuxengineering.com/blog
As given in that example I am changing in memory location 0xa0000120
I am having the same problem with a ZCU104 and Petalinux/Vivado 2020.2. I also get uio0 in Linux and I am using the same command:
That looks good but when I check the gpio interrupt counter it is still 0. Did anyone find a solution yet?
Hi folks @javichu @f35
  There is not a direct connection of toggling the interrupt line to the counter shown in /proc/interrupts without a kernel driver servicing the interrupt. Without a driver servicing the interrupt (i.e. returning IRQ_HANDLED), the counter will stay at 0.
  See this insightful post from @hokim for details and example driver code. Vitis-platform-for-ultra96v2-is-not-working
  Also I posted this related case yesterday with example userland code Axi-intc-hangs-on-boot-testcase-on-zcu104/m-p/1188729/highlight/true#M47736 using GPIO+UIO interrupts.
-Pat
