kernel 4.9 root nfs fails with ZC702
Hi all
Kernel 4.9 with NFS root is failing on Zynq zc 702 board
It is failing while fetching network ip address and mentioned as
error: root arguments are not proper
actuallly the same file system working with 3.10 Kernel
comapred both defconfig files and copied the defconfig of 3.10 to 4.9 kernel
still it is failing on 4.9 kernel so there is couple of changes in etherent driver patches, I hope
give me the patches which we shd apply for 4.9 kernel with zc702 board.
Thanks & Regards
Satish.G
G Satish Kumar
Hi Satish
Can you try with these boot arguments once (For example). It did work fine for me:-
#setenv bootargs earlycon clk_ignore_unused root=/dev/nfs     ip=192.168.100.10:192.168.100.200::::eth0:off nfsroot=192.168.100.200:/home/NFSshare,tcp ip=dhcp rw
- Boot with tftp server
#setenv ipaddr 192.168.100.10 ; setenv serverip 192.168.100.200;
Best Regards
Shabbir
