Observer rdpatel55
kernel module tainted while inserting module in open source Embedded Linux on XUPV2P board
Hi All,
I'm porting Embedded Linux 2.6.9 on XUPV2P board. I have written character device driver for 4bit LEDs available
on my board. Problem is that when I try to insert module I see following message on my hyper terminal
    1. kernel modulke is unreliable
    2. BUS error
After inserting module if I run list module command, I find my led device in the list with message "Tinted : G"
My hyper terminal output is as given below.
**bleep** [d1006548] XIo_Out32+0x4/0xc [xilinx_led]
LR [d10067b8] XGpio_SetDataDirection+0xb0/0xe4 [xilinx_led]
Call Trace:
[cfc4de50] [d1006d38] __func__.16431+0xc/0xfffffff4 [xilinx_led] (unreliable)
[cfc4de60] [d1006114] xilinx_ml403_led_setup+0xf8/0x1dc [xilinx_led]
[cfc4de90] [c0040be0] sys_init_module+0x120c/0x12f8
[cfc4df40] [c0002c10] ret_from_syscall+0x0/0x3c
Instruction dump:
5463043e 4e800020 7c0006ac 7c601c2c 4e800020 98830000 7c0006ac 4e800020
b0830000 7c0006ac 4e800020 90830000 <7c0006ac> 4e800020 5460c23e 5463442e
Bus error
[root@demoboard ~]# lsmod
Module                  Size  Used by    Tainted: G
xilinx_led              6428  1
Anyone if experienced such problem, then let me know the solution.
Raj
Observer rdpatel55
Re: kernel module tainted while inserting module in open source Embedded Linux on XUPV2P board
Hi All,
Problem is understood and solved by myself.
-rdpatel
Observer rdpatel55
Hi All,
-rdpatel
