Visitor wwykeham
kernel task_size exceed
I'm attempting to bring up a petalinux running on an ML605, and have everything built as far as I can tell it should be from following the various guides. I've got 64MB of the DDR set up and running at 0xa4000000, fs-boot pointed at that address, etc. but although u-boot seems fine, the kernel boot process appears to fail. This is what I getwhen I run the petalinux-jtag-boot:
Early console on uartlite at 0x40600000
bootconsole [earlyser0] enabled
Ramdisk addr 0x0000003f, Compiled-in FDT at 0xc025baa0
Oops: Exception in kernel mode, sig: 11
 Registers dump: mode=A42E1E9C
 r1=00000612, r2=C02DEA70, r3=C0FFF000, r4=C0FFF10E
 r5=00000EF1, r6=00000000, r7=00000EF1, r8=00000002
 r9=00000001, r10=A8000000, r11=A4000000, r12=C0A8BC94
 r13=408EC560, r14=00001000, r15=C02542F0, r16=00000000
 r17=C0141C64, r18=00000000, r19=C0FFF000, r20=00000000
 r21=00000000, r22=00000000, r23=C02E9000, r24=00000612
 r25=A4000000, r26=A7F801A8, r27=00000002, r28=00000000
 r29=01000000, r30=00000380, r31=C02EA2AC, rPC=C0141C64
 msr=00004600, ear=FFFFF3EB, esr=00000772, fsr=00000001
Kernel panic - not syncing: Attempted to kill the idle task!
Any suggestions as to what the cause might be? I haven't messed with it - everything should be as it came.The "Ramdisk addr 0x0000003f" looks suspicious but I'm not sure where that's been pulled in from.
Will
Visitor wwykeham
Re: kernel task_size exceed
Should have said - ISE version 14.6 and Petalinux 2013.04.
Will
