libGL error: unable to load driver: xilinx_drm_dri.so
Hi all,
I'm having a problem running a Qt application on my zcu102. I'm getting the following errors launching a demo application I've put together:
# ./demo
libGL error: driver pointer missing
libGL error: failed to load driver: xilinx_drm
Now I searched and found the same question was asked by a gentleman earlier last month, but there was actually no resolution listed: https://forums.xilinx.com/t5/Embedded-Linux/unabe-to-load-driver-xilinx-drm-dri-so/td-p/849308
Here is my configuration: I'm running essentially on the 2017.4 release. Which means I'm on Linux 4.9.0. I have enabled DRM in my kernel configuration. Here is a grep from .config with all DRM entries:
$ grep DRM .config
CONFIG_DRM=y
# CONFIG_DRM_DP_AUX_CHARDEV is not set
CONFIG_DRM_KMS_HELPER=y
CONFIG_DRM_KMS_FB_HELPER=y
CONFIG_DRM_FBDEV_EMULATION=y
# CONFIG_DRM_LOAD_EDID_FIRMWARE is not set
CONFIG_DRM_GEM_CMA_HELPER=y
CONFIG_DRM_KMS_CMA_HELPER=y
# CONFIG_DRM_I2C_ADV7511_LEGACY is not set
# CONFIG_DRM_I2C_CH7006 is not set
# CONFIG_DRM_I2C_SIL164 is not set
# CONFIG_DRM_I2C_NXP_TDA998X is not set
# CONFIG_DRM_HDLCD is not set
# CONFIG_DRM_MALI_DISPLAY is not set
# CONFIG_DRM_RADEON is not set
# CONFIG_DRM_AMDGPU is not set
# CONFIG_DRM_NOUVEAU is not set
# CONFIG_DRM_VGEM is not set
# CONFIG_DRM_UDL is not set
# CONFIG_DRM_AST is not set
# CONFIG_DRM_MGAG200 is not set
# CONFIG_DRM_CIRRUS_QEMU is not set
# CONFIG_DRM_QXL is not set
# CONFIG_DRM_BOCHS is not set
# CONFIG_DRM_VIRTIO_GPU is not set
CONFIG_DRM_BRIDGE=y
# CONFIG_DRM_ANALOGIX_ANX78XX is not set
# CONFIG_DRM_DUMB_VGA_DAC is not set
# CONFIG_DRM_NXP_PTN3460 is not set
# CONFIG_DRM_PARADE_PS8622 is not set
# CONFIG_DRM_SII902X is not set
# CONFIG_DRM_TOSHIBA_TC358767 is not set
# CONFIG_DRM_I2C_ADV7511 is not set
CONFIG_DRM_XILINX=y
CONFIG_DRM_XILINX_DP=y
# CONFIG_DRM_XILINX_DP_DEBUG_FS is not set
CONFIG_DRM_XILINX_DP_SUB=y
# CONFIG_DRM_XILINX_DP_SUB_DEBUG_FS is not set
# CONFIG_DRM_XILINX_MIPI_DSI is not set
CONFIG_DRM_XILINX_SDI=y
# CONFIG_DRM_ZOCL is not set
# CONFIG_DRM_XYLON is not set
# CONFIG_DRM_ARCPGU is not set
# CONFIG_DRM_HISI_KIRIN is not set
# CONFIG_DRM_LEGACY is not set
CONFIG_DRM_XILINX_HDMI=y
CONFIG_DRM_XILINX_XVMIXER=y
So based on the wiki post (http://www.wiki.xilinx.com/Xilinx+DRM+KMS+driver) regarding building the driver, I believe I've covered all of the necessary configurations to get it build. And indeed, when I build my kernel I see the DRM drivers being built, but I never see anything that produces a xilinx_drm_dri.so or anything "DRM DRI" related.
  CC      drivers/gpu/drm/xilinx/xilinx_drm_crtc.o
  CC      drivers/gpu/drm/xilinx/xilinx_drm_connector.o
  CC      drivers/gpu/drm/xilinx/xilinx_drm_drv.o
  CC      drivers/gpu/drm/xilinx/xilinx_drm_encoder.o
  CC      drivers/gpu/drm/xilinx/xilinx_drm_fb.o
  CC      drivers/gpu/drm/xilinx/xilinx_drm_gem.o
  CC      drivers/gpu/drm/xilinx/xilinx_drm_plane.o
  CC      drivers/gpu/drm/xilinx/xilinx_cresample.o
  CC      drivers/gpu/drm/xilinx/xilinx_osd.o
  CC      drivers/gpu/drm/xilinx/xilinx_rgb2yuv.o
  CC      drivers/gpu/drm/xilinx/xilinx_vtc.o
  LD      drivers/gpu/drm/xilinx/xilinx_drm.o
  CC      drivers/gpu/drm/xilinx/xilinx_drm_dp.o
  CC      drivers/gpu/drm/xilinx/xilinx_drm_dp_sub.o
  CC      drivers/gpu/drm/xilinx/xilinx_drm_sdi.o
  LD      drivers/gpu/drm/xilinx/built-in.o
  LD      drivers/gpu/drm/built-in.o
  LD      drivers/gpu/built-in.o
  CC      drivers/staging/xilinx/hdmi/xilinx_drm_hdmi.o
drivers/staging/xilinx/hdmi/xilinx_drm_hdmi.c: In function ‘hdcp_keys_configure’:
drivers/staging/xilinx/hdmi/xilinx_drm_hdmi.c:1745:67: warning: passing argument 3 of ‘XV_HdmiTxSs_HdcpSetKey’ discards ‘const’ qualifier from pointer target type [-Wdiscarded-qualifiers]
   XV_HdmiTxSs_HdcpSetKey(HdmiTxSsPtr, XV_HDMITXSS_KEY_HDCP22_SRM, Hdcp22Srm);
In file included from drivers/staging/xilinx/hdmi/xilinx_drm_hdmi.c:50:0:
drivers/staging/xilinx/hdmi/xilinx-hdmi-tx/xv_hdmitxss.h:449:6: note: expected ‘u8 * {aka unsigned char *}’ but argument is of type ‘const u8 * {aka const unsigned char *}’
 void XV_HdmiTxSs_HdcpSetKey(XV_HdmiTxSs *InstancePtr, XV_HdmiTxSs_HdcpKeyType KeyType, u8 *KeyPtr);
  CC      drivers/staging/xilinx/hdmi/xilinx-hdmi-tx/xv_hdmitx.o
  CC      drivers/staging/xilinx/hdmi/xilinx-hdmi-tx/xv_hdmitx_sinit.o
  CC      drivers/staging/xilinx/hdmi/xilinx-hdmi-tx/xv_hdmitx_intr.o
  CC      drivers/staging/xilinx/hdmi/xilinx-hdmi-tx/xv_hdmitxss.o
  CC      drivers/staging/xilinx/hdmi/xilinx-hdmi-tx/xv_hdmitxss_log.o
  CC      drivers/staging/xilinx/hdmi/xilinx-hdmi-tx/xv_hdmitxss_coreinit.o
  CC      drivers/staging/xilinx/hdmi/xilinx-hdmi-tx/xv_hdmitxss_hdcp.o
  CC      drivers/staging/xilinx/hdmi/xilinx-hdmi-tx/xv_hdmitx_vsif.o
  CC      drivers/staging/xilinx/hdmi/xilinx-hdmi-tx/xvtc.o
  CC      drivers/staging/xilinx/hdmi/xilinx-hdmi-tx/xvtc_intr.o
  CC      drivers/staging/xilinx/hdmi/xilinx-hdmi-tx/xvtc_sinit.o
  LD      drivers/staging/xilinx/hdmi/xilinx-hdmi-tx.o
  LD      drivers/staging/xilinx/hdmi/built-in.o
  LD      drivers/staging/xilinx/built-in.o
  LD      drivers/staging/built-in.o
I did note the HDMI warnings, but I'm not using the DisplayPort right now so that shouldn't be relevant.
I should also note that the kernel modules are built and installed properly, but all of the DRM stuff is built-in anyhow. I did attempt to build the DRM as modules, but hit all kinds of issues with that so I'm stilling with building it into the kernel... that's what I want anyhow.
Any ideas?
Re: libGL error: unable to load driver: xilinx_drm_dri.so
I resolved this issue. Qt had not been cross-compiled with the -opengl es2 option.
