jimmy-tong
libGL error: unable to load driver xlnx_dri.so xlnx
I encountered the following errors when I run the ORB_SLAM2(https://github.com/raulmur/ORB_SLAM2) in the PYNQ Linux image v2.5(http://www.pynq.io/board.html) using the ZCU 104 board.
libGL error: unable to load driver: xlnx_dri.so
libGL error: driver pointer missing
libGL error: failed to load driver: xlnx
Can someone please maybe explain how can I deal with this error?
Kind regards
smahalle
Hi @jimmy-tong,
The OpenGL error comes from mali, could you please please check the below rootfs configuration changes.
Filesystem Packages ---> libs ---> libmali-xlnx ---> libmali-xlnx
Filesystem Packages ---> libs ---> libmali-xlnx ---> libmali-xlnx-dev
Thanks & Regards,
Shubhangi
jimmy-tong
Hi Shubhangi
Thanks for your kind reply.
I have tried to search the packages with the name starting with "libmail". However, it seems there are not libmail-xlnx or libmail-xlnx-dev in this image (v2.5).
What's more, apt also can not find these two packages.
Here is the bash history:
Is there any other solution to install these two packages?
Thanks & Regards
smahalle
Hi @jimmy-tong,
it's a libmali you are searching for libmail.
Thanks & Regards,
Shubhangi
jimmy-tong
Hi Shubhangi
Thanks for the kind reply.
I retried with the libmali but it seems there is not libmali-xlnx or libmali-xlnx-dev, neither.
Here is the history
Is there any other possible solution?
Thanks & Regards
Jimmy
jimmy-tong
BTW I search the available packages starting with libmali as following:
Is there any alternatives to libmali-xlnx(-dev) in this list?
Thanks & Regards
Jimmy
smahalle
Hi @jimmy-tong,
Did you enable libmali-xlnx-dev and libmali-xlnx in rootfs, Could you please once cross-check this.
There is not an alternative name for libmali-xlnx-dev.
Thanks & Regards,
Shubhangi
