ymm1995
libgcc.a not found when building OPTEE on ZCU102
I am currently trying to deploy OPTEE on ZCU102. The petalinux was installed successfully. However, when I used "make -f zynqmp.mk" from OPTEE build repo to build the system, the errors were shown below. I would truly appreciate it if anyone could provide any guidance or suggestions to solve the issue.
Thank you!
Best Regards,
Mengmei
| aarch64-xilinx-linux-ld.bfd: cannot find libgcc.a: No such file or directory
| make: *** [ldelf/link.mk:54: out/arm-plat-zynqmp/ldelf/ldelf.elf] Error 1
| make: *** Waiting for unfinished jobs....
| ERROR: oe_runmake failed
| WARNING: /home/petalinux20182/Research/petalinux/zcu102-2018.2/build/tmp/work/aarch64-xilinx-linux/optee-os/latest+gitAUTOINC+f208f17a1f-r0/temp/run.do_compile.20311:1 exit 1 from 'exit 1'
| ERROR: Function failed: do_compile (log file is located at /home/petalinux20182/Research/petalinux/zcu102-2018.2/build/tmp/work/aarch64-xilinx-linux/optee-os/latest+gitAUTOINC+f208f17a1f-r0/temp/log.do_compile.20311)
ERROR: Task (/home/petalinux20182/Research/petalinux/zcu102-2018.2/project-spec/meta-user/recipes-bsp/optee-os/optee-os.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 3086 tasks of which 2255 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
ERROR: Failed to build project
zynqmp.mk:91: recipe for target 'petalinux-build' failed
make: *** [petalinux-build] Error 255
sabankocal
Voyager
Voyager
Hi @ymm1995 ,
I replied a similar thread, related with libgcc problem, can you follow my instructions in that thread?
By the way, I'm using Petalinux 2018.2.
Saban
<--- If reply is helpful, please feel free to give Kudos, and close if it answers your question --->
ymm1995
Hi @sabankocal,
Thank you so much for your quick response! I have enabled libgcc via your instructions. However, when I tried to remake the optee project via an updated zynqmp.mk (i.e., the makefile with petalinux-config, petalinux-build, and petalinux-package but without petalinux-create), the error still existed. I double checked the rootfs configuration, and it was set correctly. Not sure why. I am currently following the readme file provided by the created project to manually build the project.
Best Regards,
Mengmei
whatement
I also encountered this problem, have you solved it?
