libgomp.so.1: cannot open shared object file: No such file or directory
I am runing my binary application on the  on arm linux system.
A  error appears :
" libgomp.so.1: cannot open shared object file: No such file or directory"
could some one give hint to this problem?
Re: libgomp.so.1: cannot open shared object file: No such file or directory
Solution for this problem:
just copy /opt/Xlinx_201604/SDK/2016.4/gnu/aarch64/lin/aarch64-inux/aarch64-linux-gnu/libc/lib/libgomp.so.1 from your computer to the arm-linux/lib folder.
have you built the required library into the filesystem? which package it belongs to?
Hi @rpccobrandi
It belongs to Openmp. But in my code I didn't use openmp.
Finally I found one library include openmp library. I think that is the reason why it need this library. My solution is using --disable openmp and the error disappear.
@roccobrandi
do you know how to use openmp on the qud-cores of the arm cortex-a53 on teh zynq.
I am experiencing a very hard time to find related materials about this.
