ajaykumar141229
libusb source code compilation failed in petalinux
Hello everyone,
I want to use libusb in petalinux 2020.2,and did the following so far
1.Enabled libusb library in rootfs by using petalinux-config -c rootfs
2.Then created one application named as libusb and copied my source code into it.
3.petalinux build
But i am getting the following error
libusb.c:9:10: fatal error: libusb-1.0/libusb.h: No such file or directory
I am able to see the include file in following path build/tmp/sysroots-components/aarch64/libusb1/usr/include/libusb-1.0
But still its showing No such file or directory
Can anyone please help me on this
CN Ajay kumar
