libxml2 SDK Integration
I'm attempting to write an application for the built in XML parser provided by petalinux. It was pretty straightforward to enable libxml2 in my build (petalinux-config -c rootfs... libxml2)
However I'm not sure how to integrate the build headers into my SDK, I've found the libxml2 source here (git clone git://git.gnome.org/libxml2)
How do I integrate that with SDK? I've attempted to add it as a library which failed due to other dependencies, any suggestions would be helpful. Thanks!
