08-22-2010 11:49 AM
I cross-compiled the light httpd server for ml403 powerpc runing on linux distribution I got from the git.xilinx.
Here are the steps I followed :
1-
CC=/opt/ELDK/4.2/usr/bin/ppc_4xx-gcc ./configure --build=powerpc-405-linux-gnu --host=i686-pc-linux-gnu --target=powerpc-405-linux-gnu -enable-shared --prefix=/usr --program-prefix= --prefix=/usr --exec-prefix=/usr --bindir=/usr/bin --sbindir=/usr/sbin --libdir=/usr/lib/lighttpd --mandir=/usr/share/man --without-pcre --without-zlib --without-bzip2
2-
CC=/opt/ELDK/4.2/usr/bin/ppc_4xx-gcc make CROSS_COMPILE=ppc_4xx-
3-
make DESTDIR=$PWD/_pkg install
After striping the files. I copyed them to the Ramdisk images I got from http://xilinx.wikidot.com/powerpc-linux
The directory are :
/usr/sbin where the binary file lighttpd exists
/usr/lib/lighttpd for the concerned libraries
I copyed a lighttp.con configuration file to /etc/lighttpd folder on the ramdisk image
The server need a start file that should be put under /etc/init.d
As this file doesn't exist on the Ramdisk image, I created the folder.
This start file looks like :
#!/bin/sh
# lighttpd Startup script for the lighttpd server
# chkconfig: - 85 15
# description: Lightning fast webserver with light system requirements
# processname: lighttpd
# config: /etc/lighttpd/lighttpd.conf
# config: /etc/sysconfig/lighttpd
# pidfile: /var/run/lighttpd.pid
# Note: pidfile is assumed to be created
# by lighttpd (config: server.pid-file).
# If not, uncomment 'pidof' line.
# Source function library
. /etc/rc.d/init.d/functions
if [ -f /etc/sysconfig/lighttpd ]; then
. /etc/sysconfig/lighttpd
fi
if [ -z "$LIGHTTPD_CONF_PATH" ]; then
LIGHTTPD_CONF_PATH="/etc/lighttpd/lighttpd.conf"
fi
prog="lighttpd"
lighttpd="/usr/sbin/lighttpd"
RETVAL=0
start() {
echo -n $"Starting $prog: "
daemon $lighttpd -f $LIGHTTPD_CONF_PATH
RETVAL=$?
echo
[ $RETVAL -eq 0 ] && touch /var/lock/subsys/$prog
return $RETVAL
stop() {
echo -n $"Stopping $prog: "
killproc $lighttpd
RETVAL=$?
echo
[ $RETVAL -eq 0 ] && rm -f /var/lock/subsys/$prog
return $RETVAL
I tried to start the server using these two ways without success :
1-
The sript fails because of this line command :
There is no such file/directory on the Ramdisk image. Is there a way to add it ?
By greping /usr/bon and /usr/sbin, I found this function "start-stop-daemon", but I don't know how to call it !
2-
I tried another way by calling directly the binary file :
root:/usr/sbin> ./lighttpd -f /etc/lighttpd/lighttpd.conf
./lighttpd: not found
Strange, the lighttpd binary file exist under /usr/sbin !!
Any helps on these two ways please ?
Lyman
