exds75
linux OS crashes during AMP reset
Hi Xilinx,
vivado/sdk/petalinux 2017.4, Microzed(7020), UCOS Xilinx SDK Repository 1.43, xapp1078 AMP
Following xapp1078, I am working on AMP project (Petalinux on cpu0 and UCOS app on cpu1) with Microzed. Now I want to reset and then restart UCOS app on CPU1, reference to https://www.xilinx.com/support/answers/53828.html.
zynq> poke 0x00000024 0x37000000 // app address
zynq> poke 0xf8000008 0xdf0d // software reset CPU1
zynq> poke 0xf8000244 0x22
zynq> poke 0xf8000244 0x20
zynq> poke 0xf8000244 0x0
zynq> poke 0xf8000004 0x0000767B // lock the slcr register access
Above commands did reset/restart UCOS app on CPU1, however, linux OS on CPU0 crashes. Below is linux on CPU0 crash information:
Unable to handle kernel paging request at virtual address ddf4a540
pgd = de5c8000
[ddf4a540] *pgd=2de1141e(bad)
Internal error: Oops - BUG: 8000000d [#1] PREEMPT SMP ARM
Modules linked in:
CPU: 0 PID: 700 Comm: poke Not tainted 4.9.0-xilinx #1
Hardware name: Xilinx Zynq Platform
task: de6c8580 task.stack: de564000
PC is at 0xddf4a540
LR is at __wake_up_common+0x4c/0x74
pc : [<ddf4a540>] lr : [<c014a5e0>] psr: 20000093
sp : de565db8 ip : 00000000 fp : a0000013
r10: ddf4a540 r9 : 00000081 r8 : 00000000
r7 : 00000001 r6 : 00000001 r5 : cfd69390 r4 : c0195130
r3 : 00000004 r2 : 00000000 r1 : 00000001 r0 : cfdb9d38
Flags: nzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment none
Control: 18c5387d Table: 2e5c804a DAC: 00000051
Process poke (pid: 700, stack limit = 0xde564210)
Stack: (0xde565db8 to 0xde566000)
5da0: cfd6938c 60000093
5dc0: 00000001 00000001 00000004 dcd48c21 cfd69200 c014a63c 00000004 00000001
5de0: cfd69200 00000114 00000021 c095a334 00000000 c0348a54 c095a334 c035b518
5e00: 00000000 de533c00 00000021 c0358384 cfd69200 00000fff 00000021 cfd69200
5e20: 00000021 dcd48c00 00000000 e098d270 cfd69280 de5190c0 de564000 c0344354
5e40: 00000800 dcd48c00 cfd6938c e098b000 b6fd4000 00000002 de6c8580 c014a97c
5e60: cfdb9d44 cfd69390 cfd69200 cfd69200 00000021 00000000 00000021 de5190c0
5e80: de564000 b6fd4150 cfc1d100 c0340dbc c03440d4 dcd48c00 00000051 00000021
5ea0: 00000001 de5190c0 00000000 00000001 00000021 de565f88 de565ed4 c0340ba4
5ec0: 00000000 c01ca76c de565ed0 de565ed4 cfdd5700 00000001 00000000 00000067
5ee0: cfdd5700 0000000a 00000000 00000017 b6fd4150 c09080cc de565fb0 18c5387d
5f00: bebe3c50 0000ddb8 bebe3c3c c010128c 00000001 b6fda000 00000003 00000001
5f20: cfd56380 c01b5518 000f8000 00000000 00001000 cfd563b8 de4a0b40 00000000
5f40: 00001000 00000003 de564000 de5190c0 de5190c0 bebe3a0c 0000000a 00000000
5f60: de564000 00000000 bebe3c3c c01ca924 de565f88 00000000 0000000a c01ca970
5f80: 00000000 bebe3a0c 00000000 00000000 00000000 0000000a b6fd4194 00000092
5fa0: c0106d24 c0106b60 00000000 0000000a 00000002 bebe3a0c 0000000a 00000000
5fc0: 00000000 0000000a b6fd4194 00000092 00000000 bebe3c64 bebe3c58 bebe3c3c
5fe0: bebe3c18 bebe39d8 b6fc59d4 b6fc58f4 60000010 00000002 d6feebfe 5c6fc5ff
[<c014a5e0>] (__wake_up_common) from [<c014a63c>] (__wake_up+0x34/0x48)
[<c014a63c>] (__wake_up) from [<c0348a54>] (tty_port_tty_wakeup+0x14/0x20)
[<c0348a54>] (tty_port_tty_wakeup) from [<c035b518>] (cdns_uart_start_tx+0x74/0x9c)
[<c035b518>] (cdns_uart_start_tx) from [<c0358384>] (uart_write+0xc4/0x174)
[<c0358384>] (uart_write) from [<c0344354>] (n_tty_write+0x280/0x400)
[<c0344354>] (n_tty_write) from [<c0340dbc>] (tty_write+0x218/0x25c)
[<c0340dbc>] (tty_write) from [<c01ca76c>] (do_readv_writev+0x28c/0x2b8)
[<c01ca76c>] (do_readv_writev) from [<c01ca924>] (vfs_writev+0x44/0x4c)
[<c01ca924>] (vfs_writev) from [<c01ca970>] (do_writev+0x44/0x7c)
[<c01ca970>] (do_writev) from [<c0106b60>] (ret_fast_syscall+0x0/0x3c)
Code: 80390006 2434623f 813d0615 38cf6375 (dcd3e268)
---[ end trace 8009f581d276c293 ]---
note: poke[700] exited with preempt_count 2
Please advise, thanks in advance
Mike
