wolflow
linux SPI for zynq
I’ would like to use Peripheral  spi:0 of Zynq Xilinx with Linux OS on the ZC706 . And I selec /device driver/SPI support/Xilinx SPI controller common module in the menu, so SPIDEV is built in the uImage. And zynq-zc706.dts is added the following sentence for SPI.
        spi_0: spi@e0006000 {
            compatible = "xlnx,ps7-spi-1.00.a";
            reg = <0xE0006000 0x1000>;
            interrupts = <0 26 4>;
            interrupt-parent = <&ps7_scugic_0>;
            speed-hz = <166666672>;
            bus-num = <0>;
            num-chip-select = <3>;
            #address-cells = <1>;
            #size-cells = <0>;
                  spidev@0 {
                      compatible = "spidev";
                      reg = <0>;  /* CS */
                      spi-max-frequency = <25000000>;
                      /*spi-cpha; Possible property */
                      /*spi-cpol; Possible property */
                      /*spi-cs-high; Possible property */
                      /*spi-3wire; Possible property */
                      /*no interrupts */
unfortunately, SPI driver can not loaded correctly, I do not find spi device in the /dev folder and the log is as following:
xspips e0006000.spi: aper_clk clock not found.
xspips: probe of e0006000.spi failed with error -2
I got linux and uboot from
https://github.com/Xilinx/linux-xlnx/releases/tag/xilinx-v2013.4
I used the following version
linux kernel version: v2013.4
uboot version: v2013.4
sorenb
You're missing 'clocks' and 'clock-names' properties in your DT (cmp: https://github.com/Xilinx/linux-xlnx/blob/master-next/arch/arm/boot/dts/zynq-zc770-xm010.dts#L316 ).
asigint
I'm having similar trouble.  I can successfully control SPI with bare metal code.  I'm trying to transition to Linux and really struggling with the SPI.  Does anyone actually have it working in Linux with a ZC706?  I have SP0 enabled as EMIO.  I have the latest kernel compiled with SPIDEV.  My devicetree has the clocks as mentioned by sorenb.  It is:
		ps7_spi_0: ps7-spi@e0006000 {
			clock-names = "ref_clk", "aper_clk";
			clocks = <&clkc 25>, <&clkc 34>;
			num-chip-select = <4>;
			reg = <0xe0006000 0x1000>;
			#address-cells=<1>;
			#size-cells=<0>;
			spidev@0{
				compatible="spidev";
				reg =<0>; //chipselect 0
				spi-max-frequency= <50000000>;
			spidev@1{
				reg =<1>; //chipselect 1
			spidev@2{
				reg =<2>; //chipselect 2
 My tree was generated by the device tree generator tool, and I added everything from #address-cells=<1> down.
I have my SS1 and SS2 wired to the FMC connector going to a SPI controled ADC card.  Again, I can control the ADC over SPI perfectly with the bare_metal BSP code.
In Linux I get /dev/spidev1.0, /dev/spidev1.1, and /dev/spidev1.2.  When I run spidev_test on either spidev1.1 or spidev 1.2, I can see the correct chip select getting set on a scope.  However, Linux completely locks up on the transmit attempt and the scope shows a SCLK (clock) that both doesn't look correct and never stops.
I've run out of ideas on how to further debug this so any comments/suggestions would be welcomed!
sorenb
I'm certainly not a SPI expert, so just some generic advice:
It sounds like you may run in some deadlock. Do you have deadlock debugging/detection enabled (cmp: https://github.com/Xilinx/linux-xlnx/commit/e8a0f03e48a0b28fb2d8137745bc7dd9da61d724 ). That might give some additional hints where a deadlock may be originating from.
asigint
Ok.  That's digging in to the kernel a bit more than I'm ready for at the moment.  My SPI needs are limited (simple polled writing).  So for now, I wrote a simple HLS block to do my SPI and that works so I'm moving on.  I'd rather use the built-in SPI, but I'll have to try your debug suggestions later.  Thanks.
wolflow
I did not verify whether SPI be controlled with bare metal code based on standalone.I changed dts that is same to your dts. and i investigate this issue that seems halted in the wait_for_completion from xspips_start_transfer. I am not sure FPGA bitstream has been loaded successfully, which is provided by xilinx FAE engineer, and just SPI control MSIO pin is connected to the FPGA pin. any suggestion is welcome.thanks.
ps, register value from SPI controller register is shown as the following.
0xf0068000 0000fc21 00000004 00000000 00000000
0xf0068010 00000000 00000001 00000000 00000000
0xf0068020 00000000 000000ff 00000001 00000001
reg:0xf00680fc 00090106
wolflow
I found FPGA done led is light.but still wait_for_completion not be finished.
wolflow
to investigate this issue, MOSI is connected to MISO in FPGA. But this issue is the same as before. any suggestion? thanks.
rfs613
A patch to prevent getting stuck in wait_for_completion is here https://github.com/Xilinx/linux-xlnx/commit/07e258388ac3433afdfa27460c340f3e737cb3d4
However that will not make the actual transfer work... I suggest checking that you have clocks correctly configured and enabled... if the SPI controller doesn't receive a clock, it will most certainly not work!
Also I noticed a potential bug in the SPI driver, relating to setting the final clock divider:
while ((baud_rate_val < 8) && (frequency /(2 << baud_rate_val)) > req_hz)
baud_rate_val++;
Upon exit from the loop, baud_rate_val could be 8. However the max value permitted is 7 according to the Zynq TRM. When written to the control register at E000600, the baud_rate_val=8 actually spills over into an adjacent field that is reserved ("write 00").
rfs613
Update: if you are using SS0 for your chip select, then check this known issue: http://www.xilinx.com/support/answers/47511.htm
After fixing that in our PL, using a scope we are seeing the correct signals on EMIO for SPI device.
wolflow
As you said for your patch, It does not make the actual transfer work, only not pending in the wait_for_completion.
clock is from reference clock when SPI controller is master mode, I suppose the clock has been configured correctly. How to check the clock configured correctly?
baud_rate_val is not greater than 8 in our project.
wolflow
Thanks. I am using SS0 in our project and I will try to do following this scenario, or will try to use SS1/SS2.
wolflow
Hi, asigint, could you share your bitstream for me and i Try it. thanks
rfs613
You can verify clocks and divisors by checking the following registers. See the Zynq TRM for details on these.
SPI_CLK_CTRL at physical address 0xF8000158
bits 13:8 are the clock divider
bits 5:4 are the clock source
bit 0 must be set to enable reference clock for SPI0 controller
APER_CLK_CTRL at physical address 0xF800012C
bit 14 must be set, to enable clock to SPI0 controller
SPI0 control register at address 0xE0006000
bits 5:3 are the baud rate divisor
The final clock rate on the SCLK signal is your master clock (we use IOPLL at 1000MHz), divided by the first divisor (we use value of 5, giving us SPI_ref clock of 200MHz), divided by the baud rate divisor (we use value 3, which divides by 16, giving us 12.5MHz SCLK rate).
wolflow
return value from these register is as following:
SLCR_SPI_CLK_CTRL: 00003f03
SLCR_APER_CLK_CTRL: 01ac444d
I did not find any wrong configuration from this value.
wolflow
good news. it works. I re-built fsbl and pack into BOOT.bin. I do not know why these fsbl impact SPI interface.
sorenb
Well, the FSBL does all the low level setup, including the clock frequencies and pin muxing. If you change your HW design you must update your FSBL.
jiahanchina
Hello, it seems you had let your spi works well. I can successfully control SPI with bare-metal code and I'm trying to transition to Linux. I'm using XC7Z010 on Microzed. I had modified the device tree and when Linux start, I can see a virtual address mapped to the new spi device.
#address-cells=<1>;
#size-cells=<0>;
bus-num = <0>;
reg = < 0xe0006000 0x1000 >;
speed-hz = <50000000>;
xlnx,has-ss0 = <0x1>;
xlnx,has-ss1 = <0x1>;
xlnx,has-ss2 = <0x1>;
device@0 {
reg = <0>; //Chip select 0
spi-max-frequency = <50000000>;
device@1 {
reg = <1>; //Chip select 1
device@2 {
reg = <2>; //Chip select 2
Except I can't find /dev/spidev1.0, /dev/spidev1.1, and /dev/spidev1.2 inside Linux. It seems I had to compile the kernel with SPIDEV?? Or I had to modify something inside the kernel? Does anyone can tell me how to do it?
Any comments/suggestions would be welcomed!
rfs613
Yes, you need to rebuild your kernel with the driver enabled, or build it as a module and load it with "modprobe". It is in the linux kernel configuration under Device Drivers -> SPI Support -> User mode SPI device driver support.
mengnantiger
hi sorenb, i met a similar problem about spi in zynq.
i used a customized board with ZC030, i wanna enable spi1 via MIO, but i cannot found /dev/spixx when liunx bring up,
the figure below is my kernel configration,
mengnantiger
and the .dts generated by petalinux has
/*is-decoded-cs = <0>;*/
/*num-cs = <1>;*/
options ,
i don't kown the reason
henry10210
Hello, thanks for the tip on AR# 47511.  I am amazed that you can piece together the exact nature of the problem from the vague technical description on the AR, and hope I can get some clarification (also considering filing a webcase, but it is the weekend, and I am not sure if I will get any further clarification).
Firstly, this is what I understand after reading http://www.xilinx.com/support/answers/47511.html:
  • In master mode, SS[x] should be driven as an output pin (of course!)
  • There is apparently a bug where if nSS0 is pulled low, the controller resets.  The workaround is to either NOT use SS0 and tie SS0 to Vcc.  I am actually unsure whether the correct workaround is NOT to use SS0 at all, or just don't use it in a multi-master setting; because the rest of the explanation makes little sense to me, like this one: "The unused input signal from the MIO/EMIO multiplexer must remain deasserted."  Taken literally, it has nothing to do with SS0 being pulled down and the SPI controller resetting.  Yes, in a multi-master situation, SS0 may perhaps be pulled down by another controller.  So exactly what is the nature of the problem?  That SS0 should NEVER be pulled down low by any other controller?  Or that SS0 should never by pulled down PERIOD--in which case SS0 just should not be used?
