diego.hurtado
linux: pl353-nand: ERASE1 command always erases block 0 in Zynq-7000
Since the pl353-nand driver was rewritten using the new NAND exec_op framework, the NAND block 0 of my device gets erased at every boot.
I may have tracked down the problem. The commands issued by nand_erase_op in nand_base.c cause the driver to perform the actual erase of the desired block and a second additional erase of the block in the row calculation. See https://github.com/Xilinx/linux-xlnx/blob/e0feaf790f13d3a5c78b4af8e89e8947335dbc35/drivers/mtd/nand/raw/pl353_nand.c#L862. This line shall not be executed in the ERASE1 case. By comparing against the old driver and adding a special case here, I do not see the problem anymore.
Also, I reckon that this line https://github.com/Xilinx/linux-xlnx/blob/e0feaf790f13d3a5c78b4af8e89e8947335dbc35/drivers/mtd/nand/raw/pl353_nand.c#L857 shall read nfc_op.cmnds[1] as it is the END_CMD (or at least it was in the old driver). I may be wrong.
Thank you,
Diego H
