Newbie avnetsam
loading linux kernel following uboot-ml507-howto.pdf
When my customer follows the howto guide for loading linux kernel, he got an error when he push PPC reset button.
By the way, first image loading was successful, only reset did not work.
And my customer also reviewed ug511.pdf and wants to know why flash erase is required on pg 44 since other guide didn't request such action before writing image onto a flash.
This is from the Error Message
Wrong Image Format for bootm command
ERROR: can't get kernel image!
   XIP Invalid Image ... OK
OK
**bleep**: 00000008 XER: 20000000 LR: 0FFBE5B4 REGS: 0fe9d5e0 TRAP: 0700 DEAR: D1052007
MSR: 00021000 EE: 0 PR: 0 FP: 0 ME: 1 IR/DR: 00
GPR00: 0FFBE530 0FE9D6D0 0FE9DB48 007FFE80 00000000 00000000 007FFF00 007FFF3A
GPR08: 061741E9 00000000 00000001 007FFE80 10000000 00000CE8 0FFCFA00 0FFDE000
GPR16: F3F7FFF5 22F06201 67D7FEB6 FF55FFF6 0FE9D7C9 00000000 0FFC981C 00000000
GPR24: 0FE9D768 00000000 00000000 0FFCAB38 0FFCABB4 007FFE80 0FFD0A1C 00000000
** Illegal Instruction **
Call backtrace:
0FFBE530 0FFAB0FC 0FFA7CBC 0FFA7E0C 0FFA1600 0FFA0678 Program Check Exception
Sam
Re: loading linux kernel following uboot-ml507-howto.pdf
Since this is a "Can't get image" error, I think you can read the Flash using XMD to verify the kernel image has been stored there correctly.
Newbie avnetsam
Please provide me a detail how to read the Flash using XMD and how to compare the read image to the original kernel image.
XMD has a function called "data_verify". It can verify the binary image file with the data in the memory.
Syntax:
XMD% data_verify <file> <address>
where file can be your kernel image file.
Address is the Flash address where your kernel image was written into.
