02-19-2020 03:38 PM
Anybody know how to get "locale" installed on a Petalinux 17.2 system?
I think locale can be part of busybox, but busybox depends on the libc. Might require some libc change first.
02-23-2020 12:09 PM
Hi @leith ,
Normally you can list locale values with "locale" command on Linux.
bluetiger@Attila-Laptop:~$ locale LANG=en_US.UTF-8 LANGUAGE=en_US.UTF-8 LC_CTYPE="en_US.UTF-8" LC_NUMERIC="en_US.UTF-8" LC_TIME="en_US.UTF-8" LC_COLLATE="en_US.UTF-8" LC_MONETARY="en_US.UTF-8" LC_MESSAGES="en_US.UTF-8" LC_PAPER="en_US.UTF-8" LC_NAME="en_US.UTF-8" LC_ADDRESS="en_US.UTF-8" LC_TELEPHONE="en_US.UTF-8" LC_MEASUREMENT="en_US.UTF-8" LC_IDENTIFICATION="en_US.UTF-8" LC_ALL=en_US.UTF-8
I think, you have a build problem related with locale, that's why you are asking.
There is another thread related with locale.
It has a problem and solution like that:
he problem is caused by an incompatibility between Ubuntu 18.04 LTS (probably some updated library) and the Python 3.5 included in Yocto / PetaLinux.
Saban
02-24-2020 09:35 AM
Yes, if I utter "locale" on my build host, the command is found and I get an output similar to what you've posted.
If I utter "locale" on my target embedded system, the command is not found. I'm attempting to include the locale command in what I'm building for my target embedded system.
I've figured out a few things. "locale" is part of glibc. Petalinux 17.2 uses glibc, I think with the "eglibc" configuration. That is, its glibc optimized for embedded applications.
I believe what I want is included in the Petaliux distribution, but its a matter of configuring Petalinux to build glibc with locale.
I've looked a little at glibc, and that's a mountain I'd rather not climb. Perhaps someone knows the incantations necessary to convince Petalinux to include locale?
Thanks in advance.
05-09-2020 07:07 AM
@leith are you solve this problem ? I have the same problem that petalinux does not has locale command
05-10-2020 07:19 AM
Hi all,
Maybe this link can help you https://stackoverflow.com/questions/38735943/yocto-how-to-install-command-locale-localedef.
There are two advice in it.
IMAGE_INSTALL_append = " glibc-utils localedef"
libc6-utils.
