vishav26
lwIP Echo Server Application - RTOS bsp
I am trying to build an echo server application in RTOS bsp using ZYBO board. The application builds successfully but while running it throws the following error:
-----lwIP Socket Mode Echo server Demo Application ------
Start PHY autonegotiation
Waiting for PHY to complete autonegotiation.
ERROR: DHCP request timed out
Configuring default IP of 192.168.1.10
Board IP: 192.168.1.10
Netmask : 255.255.255.0
Gateway : 192.168.1.1
Server Port Connect With..
echo server 7 $ telnet <board_ip> 7
Auto negotiation error
Phy setup error
Assert due to phy setup failure
I tried following some old posts to find out this error. They say this error is because I don't have a Marvell or TI Phy on my board. That is true as according to specs, my board has Realtek PHY. But what is the workaround for this? I have been following many posts but could not find a specific answer for it.
Thanks & Regards
Vishav
harinik
Hi Vishav,
Could you please let me know which release you are using?
If the phy make was the cause of your error, you would see a warning saying "not a Marvell or TI phy...."
You can modify xemacspif_physpeed file for your requirement - Realtek may require some tuning but you can use the Marvell initialization as the guideline.
Harini
mina
Hi i have the same probleme how did you resolve it ???? can you give the solution
