felven
macb driver unable to generate target frequency: 25000000
I use gig-eth-pcs-pma which connect to eth1 as phy in my hardware design. The phy addr is 0x1. The gig-eth-pcs-pma mode is 1000BaseX.
I use the SDK to get the devicetree. It use default macb driver.
However when I start linux and connect the board to my computer. It says unable to generate target frequency: 25000000.
Could someone give me advice how to solve the problem?
Thanks very much.
felven
felven
mansuramin
Hello @felven
I am having this exact issue. What did you do to resolve it?
How did you fix the Macb driver?
felven
You can see my blog.
