gxsdmw
make: mb-gcc: Command not found
I am using EDK 10.1.03  When I go into build software c code, I get the message below.  How can I fix it?  Thanks ahead.
make -f system.make program started...
make: *** [Simulation/executable.elf] Error 127
htsvn
Can you please use try to launch EDK Bash Shell from Project -> Launch EDK Shell and try to run mb-gcc command to see if
this works?
Thnx
htsvn
this works?
Thnx
gxsdmw
Thanks a lot. Now it works.
But when building the kernel and U-Boot, the following errors come out:
cp: target  '/tftpboot' is not a directory
make[2]: ***[image]Error 1
make[2]:Leaving directory '/usr/petalinux-v0.40-final/software/petalinux-dist/v
make[1]: ***[image]Error2
make[1]:Leaving directory '/usr/petalinux-v0.40-final/software/petalinux-dist/v
make: ***[image] Error2
That's quite strange. The same error doesn't find on the net. Any idea? Thanks.
pafisep
Why look for the error on the net?
The error is in your computer!
:smileyhappy:
Is /tftboot a directory ?
Have you created it ?
See the petalinux instructions.
Best regards
Paulo Ferreira
