make not generate u-boot.elf
hi .
i'm trying to create a u-boot.elf by
make zynq_zed
but i get the u-boot and u-boot.bin but not the .elf
it worked before with
make zynq_zc70x
but not any more.
any ideas ?
thanks
Hi ariels1,
I just started building u-boots for the Zynq about 10 days ago.  Every time I've built one, it has been named "u-boot", not "u-boot.elf".  I rename it to u-boolt.elf when I copy it to my Windows box to make the FSBL.
--wpd
AFAIK, u-boot never built a target with a .elf extension. The one without file extension is the ELF.
You can run 'file u-boot' to check.
Hi ariels1,
--wpd
thanks all..
