mapping irq number into device tree value
We are using zynq with linux.
I'm trying to understand what should be the value in the interrupt field in dts
for example in dts:
interuupt = < 0 20 4 >
1.
We need to use IRQ #7, does it mean the second value above should be 7 ? I'm not sure.
2.
I also not sure if the interrupt in zynq support falling edge becuase in some documentation it says that cortex A9 does not support that, so I'm not sure.
Ran
Scholar rfs613
Re: mapping irq number into device tree value
For Shared Periperal interrupts, the value in the device tree is the (IRQ - 32), eg. subtract 32 from the IRQ number. You'll want to consult Chapter 7 of the Zynq tech ref manual to understand the interrupt numbers. I suspect that when you say IRQ #7, you actually mean an interrupt from the PL, (IRQF2P[x]). These have IRQ numbers in the range 61--68, and 84--91.
See also:
https://forums.xilinx.com/t5/Embedded-Linux/Interrupt-numbers-changed-in-recent-kernels/m-p/685685/highlight/true#M15577
and
http://billauer.co.il/blog/2012/08/irq-zynq-dts-cortex-a9
Scholar rfs613
See also:
and
 Hi Thank you so much.
It really helps.
As to the second issue,I see in the link of the blog that fallind edge is no supported.
Is it really so ? I'm not sure, in some other source files, or links I see reference to falling edge with zynq.
Ran
Scholar rfs613
For most of the interrupts, only one specific configuration is supported. These are shown in Table 7.3 in Chapter 7 of the Zynq Tech Ref Manual. It also says:
Except for IRQ #61 through #68, all interrupt sensitivity types are fixed by the requesting sources and
cannot be changed.
IRQ #61 through #68 correspond to IRQF2P[7:0], which are the interrupts from the PL to the CPU. For these, you can use either high-level active, or rising edge active ("All other combinations are Reserved"). Note that you can invert your interrupt in the PL.
