MarcGV
/media/card folder is empty while it shouldn't
Hallo,
I'm working with the TRD for the video codec unit for the ZCU106 eva kit.
I coppied the boot images to the SD card and when I power on the module it succesfully boots into linux, but when I try to execute the following commands it says /media/card is emprty: vcu_gst_app ./media/card/input.cfg.
using ls in this directory also doesn't give any files.
someone that knows how to solve this?
kind regards,
Marc
florentw
Hi @MarcGV
What version of the TRD are you using.
It seems that you are missing a directory level. For 2020.1 this is /media/card/config/input.cfg and not ./media/card/input.cfg.
If you still do not see this file:
  • Do you see /media/card? Else this means that the SD card is not auto mounted
  • If you see /media/card but not the directory config, then just make sure you have copied this directory to the SD card
Florent
MarcGV
I am using 2019.2, the config folder is also not in the directory.
I currently fixed it by using a usb-stick with the config files on them instead
