Voyager
Voyager
meta-xilinx BOOT.bin generation
Hi all,
I'm using meta-xilinx 2018.2 to generate boot.bin, all works like a charm, BOOT.bin is validated on ZCU102 board :)
My question is : How can i put my all cpio.gz in the BOOT.bin ?
What i did
[user:xilinx-bootbin]% cat xilinx-bootbin_%.bbappend
# Define a new partition in BOOT.bin
BIF_PARTITION_ATTR += "linux"
## specify BIF partition attributes for Linux
require conf/fit-image.conf
FITIMAGE="${DEPLOY_DIR_IMAGE}/${FITIMAGE_ITB}"
BIF_PARTITION_ATTR[linux]="load=0x3000000"
BIF_PARTITION_IMAGE[linux]="${FITIMAGE}"
BIF_PARTITION_DEPENDS[linux]="virtual/kernel:do_build"
The trouble is the varibale is set by image recipe so when this .bbappend is parsed, the variable is not set yet... How can i do to fix that ? :)
Cheers,
Trigger
Voyager
Voyager
any info about that ? :)
