Observer omeraygor
ml405 cfi-flash partition
hi.
i want to divide flash as 3 partition. 1.to bootloader  2. to kernel 3. to rootfs.
how can i do cfi-flash partition?
thanks...
Visitor so_robert
Re: ml405 cfi-flash partition
if you use ARCH=powerpc, one way to do this is to configure it in the flat device tree.
add something like:
                         uboot@0 {
                                label = "uboot";
                                reg = <0x0 0x100000>;
                                read-only;
                        bootenv@100000 {
                                label = "bootenv";
                                reg = <0x100000 0x40000>;
                                read-only;
                        kernel@140000 {
                                label = "kernel";
                                reg = <0x140000 0x200000>;
                                read-only;
                        initrd@340000 {
                                label = "initrd";
                                reg = <0x340000 0x200000>;
                        rootfs@540000 {
                                label = "rootfs";
                                reg = <0x540000 0x2c0000>;
to the flash description in your *.dts file.
take care to be sector aligned.
active the respective configuration in the kernel setup.
for more information see Documentation/powerpc/booting-without-of.txt
regards,
robert
Visitor so_robert
add something like:
                         uboot@0 {
                                label = "uboot";
                                read-only;
                        bootenv@100000 {
                                label = "bootenv";
                                read-only;
                        kernel@140000 {
                                label = "kernel";
                                read-only;
                        initrd@340000 {
                                label = "initrd";
                        rootfs@540000 {
                                label = "rootfs";
regards,
robert
Observer omeraygor
Thanks Robert
i did. then it works...
good days...
