fpda
mmc0: Got Command Interrupt
I am trying to build a petalinux system for my Zynq based platform; when I boot petalinux i Got the following error:
U-Boot 2020.01 (Dec 15 2020 - 09:55:51 +0000)
CPU: Zynq 7z007s
Silicon: v3.1
DRAM: ECC disabled 512 MiB
Flash: 0 Bytes
NAND: 0 MiB
MMC: mmc@e0100000: 0, mmc@e0101000: 1
Loading Environment from SPI Flash... SF: Detected n25q128a13 with page size 256 Bytes, erase size 4 KiB, total 16 MiB
*** Warning - bad CRC, using default environment
In: serial@e0001000
Out: serial@e0001000
Err: serial@e0001000
Net: No ethernet found.
Hit any key to stop autoboot: 0
device 0 offset 0xd90000, size 0x40000
SF: 262144 bytes @ 0xd90000 Read: OK
## Executing script at 03000000
device 0 offset 0x270000, size 0xb10000
SF: 11599872 bytes @ 0x270000 Read: OK
## Loading kernel from FIT Image at 10000000 ...
Using 'conf@system-top.dtb' configuration
Verifying Hash Integrity ... OK
Trying 'kernel@1' kernel subimage
Description: Linux kernel
Type: Kernel Image
Compression: uncompressed
Data Start: 0x100000f8
Data Size: 4325856 Bytes = 4.1 MiB
Architecture: ARM
OS: Linux
Load Address: 0x00200000
Entry Point: 0x00200000
Hash algo: sha256
Hash value: 255287acccb04e7a25c260bfa8acc259d615c6ed205fd327a44d3fd5c4923dbf
Verifying Hash Integrity ... sha256+ OK
## Loading ramdisk from FIT Image at 10000000 ...
Trying 'ramdisk@1' ramdisk subimage
Description: petalinux-image-minimal
Type: RAMDisk Image
Data Start: 0x104250b0
Data Size: 7199106 Bytes = 6.9 MiB
Architecture: ARM
OS: Linux
Load Address: unavailable
Entry Point: unavailable
Hash algo: sha256
Hash value: 2d3c0716adc1a9b89098be5c676f982e6a75441bd711eca21d592145d0988de9
## Loading fdt from FIT Image at 10000000 ...
Trying 'fdt@system-top.dtb' fdt subimage
Description: Flattened Device Tree blob
Type: Flat Device Tree
Data Start: 0x104203e4
Data Size: 19455 Bytes = 19 KiB
Architecture: ARM
Hash algo: sha256
Hash value: bc9c075a60cab4a9872a5bb0b04b9a9a4238190df97c6bfeb21f407ee8c9d335
Booting using the fdt blob at 0x104203e4
Loading Kernel Image
Loading Ramdisk to 1e42a000, end 1eb07982 ... OK
Loading Device Tree to 1e422000, end 1e429bfe ... OK
Starting kernel ...
Booting Linux on physical CPU 0x0
Linux version 5.4.0-xilinx-v2020.1 (oe-user@oe-host) (gcc version 9.2.0 (GCC)) #1 SMP PREEMPT Mon Dec 14 20:51:46 UTC 2020
CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
OF: fdt: Machine model: xlnx,zynq-7000
earlycon: cdns0 at MMIO 0xe0001000 (options '115200n8')
printk: bootconsole [cdns0] enabled
Memory policy: Data cache writealloc
cma: Reserved 16 MiB at 0x1f000000
percpu: Embedded 15 pages/cpu s31948 r8192 d21300 u61440
Built 1 zonelists, mobility grouping on. Total pages: 129920
Kernel command line: console=ttyPS0,115200 earlycon root=/dev/ram0 rw
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
mem auto-init: stack:off, heap alloc:off, heap free:off
Memory: 484536K/524288K available (6144K kernel code, 217K rwdata, 1840K rodata, 1024K init, 131K bss, 23368K reserved, 16384K cma-reserved, 0K highmem)
rcu: Preemptible hierarchical RCU implementation.
rcu: RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
Tasks RCU enabled.
rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
efuse mapped to (ptrval)
slcr mapped to (ptrval)
L2C: platform modifies aux control register: 0x72360000 -> 0x72760000
L2C: DT/platform modifies aux control register: 0x72360000 -> 0x72760000
L2C-310 erratum 769419 enabled
L2C-310 enabling early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 ID prefetch enabled, offset 1 lines
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 cache controller enabled, 8 ways, 512 kB
L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76760001
random: get_random_bytes called from start_kernel+0x260/0x440 with crng_init=0
zynq_clock_init: clkc starts at (ptrval)
Zynq clock init
sched_clock: 64 bits at 333MHz, resolution 3ns, wraps every 4398046511103ns
clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0x4ce07af025, max_idle_ns: 440795209040 ns
Switching to timer-based delay loop, resolution 3ns
Console: colour dummy device 80x30
Calibrating delay loop (skipped), value calculated using timer frequency.. 666.66 BogoMIPS (lpj=3333333)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
CPU: Testing write buffer coherency: ok
CPU0: Spectre v2: using BPIALL workaround
missing device node for CPU 1
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x100000 - 0x100060
rcu: Hierarchical SRCU implementation.
smp: Bringing up secondary CPUs ...
CPU1: failed to boot: -1
smp: Brought up 1 node, 1 CPU
SMP: Total of 1 processors activated (666.66 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
futex hash table entries: 512 (order: 3, 32768 bytes, linear)
pinctrl core: initialized pinctrl subsystem
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor menu
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
zynq-ocm f800c000.ocmc: ZYNQ OCM pool: 256 KiB @ 0x(ptrval)
e0000000.serial: ttyPS1 at MMIO 0xe0000000 (irq = 25, base_baud = 6249999) is a xuartps
e0001000.serial: ttyPS0 at MMIO 0xe0001000 (irq = 26, base_baud = 6249999) is a xuartps
vgaarb: loaded
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
mc: Linux media interface: v0.10
videodev: Linux video capture interface: v2.00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
EDAC MC: Ver: 3.0.0
FPGA manager framework
Advanced Linux Sound Architecture Driver Initialized.
clocksource: Switched to clocksource arm_global_timer
thermal_sys: Registered thermal governor 'step_wise'
NET: Registered protocol family 2
tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
TCP: Hash tables configured (established 4096 bind 4096)
UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
PCI: CLS 0 bytes, default 64
Trying to unpack rootfs image as initramfs...
Freeing initrd memory: 7032K
hw perfevents: no interrupt-affinity property for /pmu@f8891000, guessing.
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
workingset: timestamp_bits=14 max_order=17 bucket_order=3
jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
io scheduler mq-deadline registered
io scheduler kyber registered
zynq-pinctrl 700.pinctrl: zynq pinctrl initialized
GPIO IRQ not connected
XGpio: gpio@41200000: registered, base is 1023
XGpio: gpio@41200000: dual channel registered, base is 1022
XGpio: gpio@41210000: registered, base is 1021
dma-pl330 f8003000.dmac: Loaded driver for PL330 DMAC-241330
dma-pl330 f8003000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
brd: module loaded
loop: module loaded
spi_master spi0: cannot find modalias for /amba/spi@e000d000/flash@0
spi_master spi0: Failed to create SPI device for /amba/spi@e000d000/flash@0
libphy: Fixed MDIO Bus: probed
CAN device driver interface
e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-pci: EHCI PCI platform driver
usbcore: registered new interface driver usb-storage
i2c /dev entries driver
cdns-i2c e0004000.i2c: 400 kHz mmio e0004000 irq 22
cdns-wdt f8005000.watchdog: Xilinx Watchdog Timer with timeout 10s
EDAC MC: ECC not enabled
Xilinx Zynq CpuIdle Driver started
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
mmc0: SDHCI controller on e0100000.mmc [e0100000.mmc] using ADMA
mmc1: SDHCI controller on e0101000.mmc [e0101000.mmc] using ADMA
ledtrig-cpu: registered to indicate activity on CPUs
clocksource: ttc_clocksource: mask: 0xffff max_cycles: 0xffff, max_idle_ns: 537538477 ns
timer #0 at (ptrval), irq=41
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
mmc0: Got command interrupt 0x00030000 even though no command operation was in progress.
mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
mmc0: sdhci: Sys addr: 0x00000000 | Version: 0x00008901
mmc0: sdhci: Blk size: 0x00000000 | Blk cnt: 0x00000000
mmc0: sdhci: Argument: 0x00000000 | Trn mode: 0x00000000
mmc0: sdhci: Present: 0x01ff0000 | Host ctl: 0x00000001
mmc0: sdhci: Power: 0x0000000f | Blk gap: 0x00000000
mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x00004007
mmc0: sdhci: Timeout: 0x00000000 | Int stat: 0x00000000
mmc0: sdhci: Int enab: 0x00ff0083 | Sig enab: 0x00ff0083
mmc0: sdhci: ACmd stat: 0x00000000 | Slot int: 0x00000000
mmc0: sdhci: Caps: 0x69ec0080 | Caps_1: 0x00000000
mmc0: sdhci: Cmd: 0x0000371a | Max curr: 0x00000001
mmc0: sdhci: Resp[0]: 0x00000000 | Resp[1]: 0x00000000
mmc0: sdhci: Resp[2]: 0x00000000 | Resp[3]: 0x00000000
mmc0: sdhci: Host ctl2: 0x00000000
mmc0: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000
mmc0: sdhci: ============================================
fpga_manager fpga0: Xilinx Zynq FPGA Manager registered
NET: Registered protocol family 10
Segment Routing with IPv6
sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
NET: Registered protocol family 17
can: controller area network core (rev 20170425 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20170425)
can: broadcast manager protocol (rev 20170425 t)
can: netlink gateway (rev 20190810) max_hops=1
Registering SWP/SWPB emulation handler
of-fpga-region fpga-full: FPGA Region probed
hctosys: unable to open rtc device (rtc0)
of_cfs_init
of_cfs_init: OK
ALSA device list:
No soundcards found.
mmc1: new high speed MMC card at address 0001
Warning: unable to open an initial console.
Freeing unused kernel memory: 1024K
Run /init as init process
mmcblk1: mmc1:0001 Q2J55L 7.09 GiB
mmcblk1boot0: mmc1:0001 Q2J55L partition 1 16.0 MiB
mmcblk1boot1: mmc1:0001 Q2J55L partition 2 16.0 MiB
mmc0: sdhci: Argument: 0x80000c08 | Trn mode: 0x00000000
mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x00008007
mmc0: sdhci: Cmd: 0x0000341a | Max curr: 0x00000001
mmcblk1rpmb: mmc1:0001 Q2J55L partition 3 4.00 MiB, chardev (245:0)
mmc0: sdhci: Argument: 0x000001aa | Trn mode: 0x00000000
mmc0: sdhci: Cmd: 0x0000081a | Max curr: 0x00000001
mmc0: sdhci: Cmd: 0x00000502 | Max curr: 0x00000001
mmcblk1: p1 p2
udevd[73]: starting version 3.2.8
random: udevd: uninitialized urandom read (16 bytes read)
udevd[74]: starting eudev-3.2.8
Anyone who can help me out?
thanks in advance
fpda
Maybe some more information:
I try to boot from flash I configured:
system-conf.dtsi:
chosen {
bootargs = "console=ttyPS0,115200 earlycon root=/dev/ram0 rw";
stdout-path = "serial0:115200n8";
&qspi {
#address-cells = <1>;
#size-cells = <0>;
flash0: flash@0 {
spi-max-frequency = <50000000>;
partition@0 {
label = "boot";
reg = <0x00000000 0x00270000>;
partition@1 {
label = "kernel";
reg = <0x00270000 0x00b10000>;
partition@2 {
label = "bootenv";
reg = <0x00d80000 0x00010000>;
partition@3 {
label = "bootscr";
reg = <0x00d90000 0x00008000>;
My xsa file is just a Zynq PS with 2 AXI Blocks and default presets (DDR and Fixed IO)
For creating BOOT.BIN I used:
petalinux-package --boot --u-boot --fsbl --fpga --force
I flashed:
program_flash -f BOOT.BIN -offset 0 -flash_type qspi_single -fsbl zynq_fsbl.elf -cable type xilinx_tcf url TCP:127.0.0.1:3121
program_flash -f boot.scr -offset 0xD90000 -flash_type qspi_single -fsbl zynq_fsbl.elf -cable type xilinx_tcf url TCP:127.0.0.1:3121
program_flash -f image.ub -offset 0x270000 -flash_type qspi_single -fsbl zynq_fsbl.elf -cable type xilinx_tcf url TCP:127.0.0.1:3121
