mmc0 & mmc1 are switched in U-boot and Kernel
I have in my device tree in U-boot two sdhci interfaces defined as below
Consequently, I defined boot arguments in u-boot to boot from mmc 0 as this is my primary sd card.
However when kernel is booting, the sdhci devices are switched so my primary sd card became at mmc1
Does anyone have idea how to control or define mmc order in the kernel? or in general how to make the kernel capture the same mmc order as in u-boot?
Thanks in Advance
Re: mmc0 & mmc1 are switched in U-boot and Kernel
I tried to define mmc 0 & 1 in the device tree for the kernel with the same naming but not changing.
Any support please
For who is interested.
This blog explains another workaround.
So instead of defining sdroot0=..... root=/dev/mmcblk0p2, we can use UUID number of the file system.
So first get the UUID (using command part uuid mmc $sdbootdev:2 founduuid)
then use founduuid to boot (sdboot= ......root=PARTUUID=$founduuid).
If anyone sees limitations or restrictions or drawbacks using UUID, please advise
