mmcblk* vs sd*
Hello.
I'm trying to boot linux using FPGA board.
In most manuals, they say I can find  mmcblk* when I connect sd(microsd)card.
However, in my case, there is no  mmcblk* but sdb at the /dev/
What is the difference between  mmcblk and sd??
Can I use sdb to mount and boot linux??
Young
Re: mmcblk* vs sd*
Hi Young,
You might need to format your SD card to FAT16/32 filesystem format and try.
Best Regards
Kranthi
