maikonnascimento
modify device tree for new Interrypt from PL
Hi ,
I am trying to add a new IRQ in my device tree to handle the interrupt that comes from my PL.
I have a zturn board with zynq 07z020, from the kit I have a zynq-zturn.dts file , which I added a pl.dtsi file
that I got from petalinux (I was trying to generate my dtb from my bit file from Vivado).
I am lost regarding where I have to edit or modify the dts or dtsi , I noticed that petalinux ,
created the pl.dtsi and has the right addresses from the peripherals mapped into memmory axi_vdma_0 and v_tc_0, then I added at the bottom :
observer: observer@44000000 {
                    compatible = "xlnx,observer-1.01.a";
                    interrupt-names = "irq2";
                    interrupts = <0 32 1>;
                    interrupt-parent = <&gic>;
                    reg = < 0x44000000 0x10000 >;
my current IRQ list from cat /proc/interrupts is :
\0x1b[0;31mZ-turn#\0x1b[m cat /proc/interrupts
CPU0 CPU1
29: 234 220 GIC 29 twd
35: 0 0 GIC 35 f800c000.ocmc
39: 43 0 GIC 39 f8007100.adc
40: 0 0 GIC 40 f8007000.devcfg
41: 0 0 GIC 41 f8005000.watchdog
43: 7846 0 GIC 43 ttc_clockevent
45: 0 0 GIC 45 f8003000.dmac
46: 0 0 GIC 46 f8003000.dmac
47: 0 0 GIC 47 f8003000.dmac
48: 0 0 GIC 48 f8003000.dmac
49: 0 0 GIC 49 f8003000.dmac
51: 3 0 GIC 51 e000d000.spi
53: 0 0 GIC 53 ehci_hcd:usb1
54: 0 0 GIC 54 eth0
56: 58 0 GIC 56 mmc0
57: 32 0 GIC 57 cdns-i2c
61: 1 0 GIC 61 SII902x_det
62: 0 0 GIC 62 xilinx-vdma-controller
63: 0 0 GIC 63 0-0053
72: 0 0 GIC 72 f8003000.dmac
73: 0 0 GIC 73 f8003000.dmac
74: 0 0 GIC 74 f8003000.dmac
75: 0 0 GIC 75 f8003000.dmac
82: 51 0 GIC 82 xuartps
146: 0 0 zynq-gpio 50 K1
IPI1: 0 39 Timer broadcast interrupts
IPI2: 623 370 Rescheduling interrupts
IPI3: 0 0 Function call interrupts
IPI4: 79 28 Single function call interrupts
IPI5: 0 0 CPU stop interrupts
IPI6: 8 14 IRQ work interrupts
IPI7: 0 0 completion interrupts
Err: 0
Best Regards.
maikonnascimento
I have a zturn board , and what I did to get my IRQ in the /proc/interrupts was to modify the file
zynq-zturn-xylon.dtsi where I added a new block based on some tip from https://forum.digilentinc.com/topic/9174-linux-driver/
amba_pl {
        #address-cells = <0x1>;
        #size-cells = <0x1>;
        compatible = "simple-bus";
        ranges;
        gpio2@43c20000 {
            #gpio-cells = <0x2>;
            #interrupt-cells = <0x2>;
            compatible = "generic-uio";
            gpio-controller;
            interrupt-controller;
            interrupt-parent = <0x4>;
            interrupts = <0x0 0x20 0x4>;
            reg = <0x43c20000 0x10000>;
            xlnx,all-inputs = <0x1>;
            xlnx,all-inputs-2 = <0x0>;
            xlnx,all-outputs = <0x0>;
            xlnx,all-outputs-2 = <0x0>;
            xlnx,dout-default = <0x0>;
            xlnx,dout-default-2 = <0x0>;
            xlnx,gpio-width = <0x3>;
            xlnx,gpio2-width = <0x20>;
            xlnx,interrupt-present = <0x1>;
            xlnx,is-dual = <0x0>;
            xlnx,tri-default = <0xffffffff>;
            xlnx,tri-default-2 = <0xffffffff>;
then I do see my IRQ on the list, I don't know if this is the best solution but it is my progress up to now.
maikonnascimento
amba_pl {
        ranges;
        gpio2@43c20000 {
            gpio-controller;
stephenm
