07-30-2018 06:15 AM
Hello!
I`m using Petalinux 2017.2 and having trouble modifying /etc/sudoers file.
I found /etc/sudoers is a part of sudo package, so I added sudo folder to <petalinux>/project-spec/meta-user/recipes-core with sudo_%.bbappend file and sudo subfolder.
sudo_%.bbappend contains the only line
FILESEXTRAPATHS_append := "${THISDIR}/${PN}:"
and sudo subfolder contains modified etc/sudoers file.
Where am I wrong?
07-31-2018 03:12 PM
Hi @mishuk,
Which file you are trying to modify ?
sudo recipe should be under recipes-extended as show below http://cgit.openembedded.org/openembedded-core/tree/meta/recipes-extended/sudo?h=morty
<plnx-proj-root>/project-spec/meta-user/recipes-extended/sudo_%.bbappend
08-16-2018 12:08 AM
Finally I got the desired result modifying files:
project-spec/meta-user/recipes-core/sudo/sudo/sudoers
project-spec/meta-user/recipes-core/sudo/sudo_%.bbappend
sudo_%.bbappend:
SRC_URI += "file://sudoers"
do_install_append () {
install -m 0644 ${WORKDIR}/sudoers ${D}${sysconfdir}/sudoers
You proposed another way through modifying recipes-extended layer. Which way is the best? I mean maintainability in long-range perspective.
